Results 1 to 3 of 3
Thread: digital dash into mx83
    May 2006
    tas
    Default digital dash into mx83
    hey blokes.
    i cant find pin-outs for both dashes. i came across a LHD one posted on here as well as a few random wires but not a full list.
    same with google. finding heaps of ECU jzx81 pin outs but not dash ones. ive also looked in the wiring diagram thread to no avail. i found curssida posted that he had put them up before but again couldn't find those.
    also ive got a jzx81 digital fuel sender + speedo sender (i have a S1 mx83) ill need jzx81 or jzz30 oil press and water temp sensors aswell??
    seeing as ill need a tacho adaptor for the analogue cluster with a 2j, may as well swap the digi one over while the car is off the road. well a good excuse anyway. i much prefer the digital over boring analogue, had one in my soarer and loved it!
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Default Re: digital dash into mx83
    the standard water temp sender and oil pressure switch work fine with the digi dash. The last swap I did was converting a digital dash setup to analogue, I just traced out the wires in the loom manually to make the required connections.
    May 2006
    tas
    Hhmm, I guess while it could be time consuming i could trace it. But that doesn't help me at all with the digi dash
    -JZX83 in the build
    <3 7M sludge pump
