Results 61 to 66 of 66
Thread: Fiberglass inlet manifold
  1. #61
    Default Re: Fiberglass inlet manifold
    Quote Originally Posted by ed_jza80
    yeah, chopped mat wouldve been way better
    what material did you make the plug out of?
    The plug was painted (and painstakingly polished) plaster. Remarkably tough, even when you bash it violently against a steel work bench....
  2. #62
    Quote Originally Posted by Ben Wilson
    The big difference is they use pre-preg and vac bags, so the cloth is mouldable and doesn't fray and lift like wet lay up. I might give it another go some time in the future, I just enjoy working with metal so much more
    prepreg is great to use. maybe try with a multi layers of lighter glass instead of heavyer glass if its not forming properly and do it in a warm room.
  3. #63
    I got the thinnest woven mat they had. The epoxy just didn't seem sticky enough to hold it to the tube. What I could have tried was wrapping some sort of peel ply over the lot to hold it in place...
    There are a few things I probably should have tried, perhaps next time.....
  4. #64
    Making a hotter mix (i.e. more hardener) will also assist in the lay up process. As will putting a layer onto the mould and letting it become tacky before wrapping the cloth over it. Chopped strand is much nicer to work with for that sort of thing though.
  5. #65
    You can't do a hot mix with epoxy (one of the other reasons why polyester is nice).
  6. #66
    Oh yeah, forgot you were using epoxy resin. That does make the sticky, nasty, ugly, feralness worse.
  1. For the love of a tractor engine: The life and times of the 18R-G
    Last Post: 28-04-2024, 03:01 PM
  2. 4AGTE - Exhaust manifold warping
    By tan18d in forum Tech and Conversions
    Last Post: 05-05-2009, 05:36 PM
  3. 4AGE small port --> making the ports smaller again
    By 92-GTI in forum Tech and Conversions
    Last Post: 09-03-2006, 02:51 PM
  4. T3/T4 Manifold
    By Ben in forum Tech and Conversions
    Last Post: 25-01-2006, 10:08 AM
