Page 1 of 4 123 ... LastLast
Results 1 to 15 of 57
Thread: JZGE Engine info
    Junior Member Backyard Mechanic HIZOKU's Avatar
    May 2006
    Default JZGE Engine info
    Looking to build a JZ engine of some sort NA looking for the pro's and cons as a base to start with.
    For example 1J has better bore/stroke ratio for higher revs but a 2jz has 500cc more
    1jzge/2jzge run distributors GTE version do not.
    i Already have a 1jzgte in a car so was sort of thinking well JZX81 has 1jz why not chuck a nice NA in the mx32 keep them all sort of in the family.
    what ever engine i use will be run from a after market computer as i will be running GTR ITB on it
    Next question worth going VVTi version or not?
    [Gentlemen's Club]
    Default Re: JZGE Engine info
    1JZGE may be a bit harder to find than a 2JZGE My VVTI version is a nice smooth little motor not a real lot of torque but goes ok given a few revs
    Jealousy is a curse
    May 2006
    Alright After spending a good 8 hours researching
    your right 1JZ NA is hard to find and performance parts are even harder,
    SO now it comes to 2JZ what engine should i start with a GTE or GE? are the heads different other then one running a distributor? reason i ask is the GTE Block as oil squirters and a GE does not? and do GTE exhaust manifolds bolt on to GE or the other way around?
    [Gentlemen's Club]
    worships the 2JZ (GE lol) 1st year Apprentice uncivilised's Avatar
    i got a 2jzge non vvti in the cressida. its goes pretty good for what it is. mods where 3inch exhaust, CAI intake with pod, lexus is300 LHD ebay headers modified to fit and an apexi safc. its pulling 140kw atw, which is about average for those mods.
    how far did you want to go with mods? i would assume a 2jzge would suffice without having to resort to GTE internals.
    May 2006
    well mods list im looking at
    2 1/2 inch exhuast to diff with twin 2inch pipes
    ITB
    extractors
    Cams
    Valve springs
    aftermarket ECU
    there will be other things i have forgotten or im thinking about but unsure for example that is head work like port polish and MAYBE i will do pistons just depends on how much i pick up engine for and so on
    but basic mods you have are diff on the cards
    [Gentlemen's Club]
    May 2006
    More research has me stuck also between VVTI and non any help on that is good
    [Gentlemen's Club]
    2JZGE VVTi.
    Nice exhaust
    Cold air induction
    Aftermarket management.
    Done.
    To do the list you have written above, don't expect much change from $10k.
    And it just wouldn't be worth it.
    Its just not worth opening up the motor unless you are going to spend big dollars.
    Perth WA
    Quote Originally Posted by HIZOKU View Post
    Yep so hard to find that I've had one for sale for years now for $400 and still have the fucking thing!
    Fwiw, I also have 2JZGE and 2JZGE VVTi motors, along with GTR throttle bodies in the shed, when you decide on your pathway, give me a shout.
    May 2006
    Will do CLG,
    so far im thinking just 2JZGE non VVTi as im finding it hard to find anything NA for the VVti
    currently just researching also what sump i might need to use and as uch NA research as i can find
    [Gentlemen's Club]
    Whats your budget for this build?
    May 2006
    No budget as such
    Not saying i want to spend 30k, but sort of want to do what i have said
    2JZGE
    RB26 ITB
    CAMSHAFTS
    CAM GEARS
    EXTRACTORS
    VALVE SPRINGS
    Then MAYBE, and this is a huge maybe, depending on condition of engine and cost of it i will do head gasket ,port polish,
    Car will run a Autronic of some sort as i do run a Autornic in the JZX81 and want to keep with something i know, and yes i know the cost i have budgeted for that
    but yeah it more a long term engine build as the mx32 is running fine nothing wrong with it at all so no rush in building the motor
    [Gentlemen's Club]
    Sounds feasible then.
    But I'd still choose the VVTi over the non, especially since you are remaining NA.
    Just look at the BEAMS 3SGE results!
    May 2006
    Yeah i understand the VVTi with more torque but i can not find extractors for them and aftermarket camshafts where as non VVTi seem to have alot more
    [Gentlemen's Club]
    2JZGE VVTi's come with factory extractors (quite nice ones at that).
    But chances are off the shelf stuff won't fit in your engine bay, so you'll need to custom build it.
    And cams you can just get welded and reground.
    you can get cams for the 2jzge vvti google it, US clublexus forums has info on it they are from brian crower cams i think but they dont show up on their website
  1. Toyota R Engine History
  2. 2TGEU Engine Number Info?
    By 71TA22 in forum Tech and Conversions
    Last Post: 23-03-2010, 03:44 PM
  3. MA70 --> JZA70 Conversion
