Results 16 to 27 of 27
Thread: Going to CDI - whats the best way
    Default Re: Going to CDI - whats the best way
    so thumbs up for EDIS? it will be upto the task with the Megajolt?
    looks to be pretty easy to setup. i got sick of cooking at the wreckers yesterday trying to get a trigger wheel/harmonic balancer off a falcon... will try again another day with better tools and look at grafting it to my motor
    pffft rev limit lol. when it throws a rod you lift!!
    Never late in an x8
    Quote Originally Posted by litldv8 View Post
    my hilux is running it with the toyota crank angle sensor admittidly i machined off the teeth and fitted a trigger wheel that i had laser cut to it.
    works quite well on my setup.
    neil
    In other words... it doesn't work with toyota CAS
    What are you using for the actual spark control though? Cos i've been saying, EDIS is not a complete solution for programmable ignition... you still need an ECU like megajolt or microsquirt.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    Jan 2008
    queensland
    megasquirt
    2009 aurion
    Purple 2000 Hilux - 1UZ
    0402727834 Grease Monkey turbo ke20's Avatar
    haltech platinum 2000 and M&W pro 16 6 channel CDI is the go
    Yes it will set you back a few grand but in my opinion its the best setup.
    PROWIRE PERFORMANCE WIRING
    Specialising in:
    -Haltech
    -Full Rewires
    -Engine conversions
    -Custom Air Con. Installations
    -Drag, circuit & show car wiring
    Justin Moore
    0402 727 834
    http://www.facebook.com/profile.php?...88667244568569
    And that's a bit of a waste considering all he wants is a 10x10 spark advance table for his prehistoric carby motor
    Current rides...
    2) White RA25ST
    If EDIS starts too look dificult (mounting crank wheel and sensor) you could just run the 7mgte coil packs, 7mgte ignitors and 7mgte CAS with the mega jolt. If you have all the gear it may be an option, just a little more wiring, I heard the 7mgte coil packs a punch.
    Roger
    really???? hmm might be an option. i am trying to keep the thing as simple as possible.
    just found i can buy the 36tooth wheel for nix online, saves removing and cutting up a falcon harmonic balancer
    Never late in an x8
    andrew_mx83,
    Diy autotune who sell the megajolt sell 36-1 wheels. I have had success with bolting them on through the centre crank pully bolt, welding them on the crank pully, and bolting on a pcd on the crank pulley. Not to difficult to do depends whether your into wiring or fitting.
    Roger
    haha i like the fitting & turning... motor already has countless hours of machining time in it, it is a 7m-ge/5m-e/7m-gte hybrid for ultimate rev-ability
    however i am interested in running it without the EDIS and sticking to 7m bits, do you know what is involved in this?
    Never late in an x8
    You should take this discussion over to the MegaSquirt forums since thats probably you best & cheapest option.
    Ask in here: http://www.msefi.com/viewforum.php?f=89
    Looks like the megajolt is not out yet and only the megajolt light, this only runs with edis therfore edis is probably your best bet still unless you went full megasquirt which would cost more and more complex.
    Roger
    i thought the megasquirt only had 2 ignition channels?
    i think i will just go down the EDIS + megajolt jr route.... looks simple, affordable and should do what i want.
    Never late in an x8
