microtech should have an internal one.
will work fine with your setup
external map sensor is only really used for high boost apps (over 20 psi)
just after a map sensor for the 4a (redtop)
it is running a turbo setup with an lt10 ecu so will i need to change anything to make it suit or can it just be plugged in? or is there another map sensor i should be using from something different that will work better or is the stock one just as good when being used with boost????
if anyone has one let me know thanks.
PROWIRE PERFORMANCE WIRING
Specialising in:
-Haltech
-Full Rewires
-Engine conversions
-Custom Air Con. Installations
-Drag, circuit & show car wiring
Justin Moore
0402 727 834
http://www.facebook.com/profile.php?...88667244568569
Yea thats good I wasn't sure if I could run it or it needed to run an external one, thats good then thanks for that,
if you need more fuel adjustment with the basic map sensor option for a microtech (20psi internal sensor) above 20psi, there are some ways around it. If you need any help sing out.![]()
cheers for that RT40
