The bit with all the hoses is the end of the common vacuum rail. The fat hose comes from
the ISCV, but it seems that yours has been plugged. Therefore, right now all your idle air
is going in thru that open port. As you have discovered, if you partially close that port off
with your thumb, the idle speed will drop.
By way of explanation; all the idle air for the 20V usually enters the vacuum rail by way of
the ISCV, and from the rail into each of the individual intake throttles downstream of the
butterflys. If you shut off the idle air, the engine dies. One way round (if you don't have a
working ISCV) is to crack the throttles open using the throttle arm stop screw located
between the centre two throttles. Or, easier, just attach some kind of cap to the end of
that open port, and drill a smaller hole in it. By adjusting the size of the hole, you will be
able to fix your idle at whatever rpm you prefer.
Downside is that there will be no ECU compensation for temperature, so your hot idle
will be a higher than when cold. Means cold starts might need a bit of a tickle on the
throttle until the engine warms up.
Cheers... jondee86
