Results 16 to 29 of 29
Thread: 1JZ Thermo CFM?
    Default Re: 1JZ Thermo CFM?
    Quote Originally Posted by CrUZida View Post
    If you want electric, I would ONLY use EL/AU/etc Falcon fans (or the Mondeo ones).
    They come fully shrouded and will outflow pretty much every fan on the market (bar a few).
    Piss easy to fit, and highly reliable.
    But, from memory they are about 85mm deep at their thickest (or is it 70mm?? can't remember)
    My car is running with just one EL fan hooked up (both are there, not wired) - and it clearly works well. 30+ deg days and i'm still not overheating with only one fan..
    With both on though, car will sound like it is going to take off, only downside i can think of
    ed: Perhaps i should add that this is with an ebay alloy rad, mx83 1jz. Ebay s/h genuine ford ones, ~$70
    Jan 2007
    queensland
    the only problem i have with running those fans and shroud is how dogey it looks unless the radiator is just as big, and can use the brackets/mounting points from the stock shroud... all the EL thermo fan conversions i've seen look bodgey and have zip ties, the shroud hangs over the radiator in all different places.. just looks crap...
    I've used them on an MX73 radiator, an MA70, and an MZ10, and all 3 have almost been a mm perfect fit.
    Its probably only 4cyl cars where they are too big.
    Jan 2007
    queensland
    definitly good to know as i'm thinking of a MX73 project.....
    most of them are drift shitters that i've seen... those c**ts just don't give a shit about thier cars... it's baller to be hacked up and dodge...
    May 2006
    tas
    Quote Originally Posted by mattysshop View Post
    dunno about baller, just easier/quicker/faster/safer to use zippie ties on a car your expecting to stack.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Yep EL Falcoon ones here on the 1uz.
    Keeps the temps well low. Using both fans
    I do not dorifto or circuit so street only comparison here.
    Junior Member Backyard Mechanic HIZOKU's Avatar
    May 2006
    My drifter the bodykit is held on by cable ties as when you stack the cable tie breaks and lets the whole bar come off in one bit not get smashed into lots of lil bits
    So alot of people using EL ones I got some prices in regards to spal ones i will prob go with them
    [Gentlemen's Club]
    Take the time with a stanley knife to clean it up and it looks fine - fair bit needs to be cut. EL lines up well with MX83 size, width is spot on - from memory AU is too big.
    I will confess that i never finished the job and the very last mounting point i used a cable tie, but i was at pains to cut the shroud so it tucked into the little tabs on the bottom of the rad, etc. Someday.... maybe
    Found a pic of when it was (mostly) finished and ready to go on - you could do more and cut off the wider mounting tabs etc that i'm not using, but i'd had enough of my blunt stanley knife by then
    Uploaded with ImageShack.us
    May 2006
    Wow that is good fitment
    I Also just found out that Ford Thermo Fans are twin 16" So all these twin 12" i been looking at that flow 900cfm more time to start looking at monster 16" twins
    and BTW
    EF/EL fans are 700mm wide x 420mm high
    AU fans are 660mm wide x 440mm high
    There is some messurements for people wanting to do the conversion
    [Gentlemen's Club]
    I'm pretty sure the Ford ones are twin 13" fans, or there abouts.
    There aren't too many radiators that would fit twin 16" fans!
    Oh, and don't use EF fans either, as one fan is 6V and the other is 12V.
    May 2006
    Alright i got the wrong info
    13.5" is correct Just had friend measure up some
    http://www.ozecruisers.com.au/cgi-bi...=tutorials&i=3
    here is a good wire up with over ride switch
    http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
    and a good website with LOTS of fans on it with CFM listings to
    [Gentlemen's Club]
    May 2006
    Thermo Fans CFM Hight (MM) Wide (MM) Depth (MM)
    Spal twin 12" 3168 402 656 102
    EF/EL Ford 13.5" 2340 420 700
    AU Ford 13.5" 2340 440 660
    Derale Cooling Products 13" TWN pn:16928 4000 351 723 81
    Derale Cooling Products 13" TWN pn:16934 4000 400 796 82
    FAL 225B 12" TWN 2500 393 666 66.6
    Derale Cooling Products 13" TWN pn:16028 4000 351 723 81
    Flex-a-lite 580 2500 393 666 66.6
    Flex-a-lite 490 3000 393 666 101
    Derale Cooling Products 13" TWN pn:16027 4000 457 660 95.25
    FAL 525 2500 393 666 66.6
    Flex-a-lite 410 2500 393 666 66.6
    Flex-a-lite 298 4600 444 698 101
    FAL 425 12" TWN 2500 393 666 66.6
    Flex-a-lite 480 12" TWN 3000 393 666 101
    Flex-a-lite 285 15" TWN 5500 444 809 114.3
    Alright did not come out as good as i wanted to on the forum but there you go guys using a huge list of fans i have found with size in MM and Flow rates
    [Gentlemen's Club]
    Any chance you can use the Autronic to control the hydraulic fan? And is the hydraulic fan working now?
    I would suggest keeping that setup if it's being or can be controlled properly.
    It didn't have any cooling problems in its past life in Adelaide, which says alot for the setup it has, and replacing the water pump is actually possible without replacing the whole unit, so it's not as prohibitively expensive as often thought.
    I did a bit of the work on that car including wiring the Autronic & fitting the coils, it's good to hear it's still around & going to get driven again.
    One thing I always wanted to fix on it was the idle up valve, loud & hard to controll with an air filter on it. You might want to plumb it up to the intake in front of the throttle body instead of the air filter, will make it quieter & much easier to controll the idle.
    May 2006
    Autronic can not control the stock thermo
    And good to know you wired it up i might have to pick your brain to how it is wired up as im putting in autronic boost solenoid and have meth injection plugged up and controlled by it to
    As i want to fix the speedo but also wire up other things like wideband so it and so on, im yet to have a look at the wiring waiting till i have everything
    [Gentlemen's Club]
  1. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 08:13 PM
  2. JZX81 1JZ: Analogue Dash Wiring
    By mamba in forum Engine & Driveline Conversions
    Last Post: 19-05-2007, 05:04 PM
  3. 1jz and Haltech e6k
    Last Post: 10-10-2006, 05:25 AM
