Results 16 to 18 of 18
Thread: engine crane wont jack/lift
    May 2006
    tas
    Default Re: engine crane wont jack/lift
    if its too much to have this one fixed ill do that. but id rather have this one fixed so hopefully i wont have the same problem again in a few months. a replacement ram is going to have the same cheap seals in it (assuming thats the problem).
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Oct 2009
    I had a similar problem but had the enging swinging off it and in the engine bay it was quite a concern when you are trying to line the mounts up.
    Its just cheap rubbish I suppose. Once I got the engine in and let the arm down it seemed to work ok.
    May 2006
    tas
    it wont compress if you extend it without load. but yeah wouldnt lift at all with load on it so cant pick motor up.
    should get a call tomorrow hopefully to find out what wrong with it and costs
    -JZX83 in the build
    <3 7M sludge pump
  1. Toyota BEANs, Multiplex etc
    Last Post: 14-12-2016, 06:21 AM
  2. MA70 --> JZA70 Conversion
