Results 1 to 4 of 4
Thread: 21r to replace tired 22r
    Aug 2009
    south australia
    Default 21r to replace tired 22r
    I have a 2wd hilux with a sad and tired 22r and have access to a cheap 21r in good condition
    is this an easy swap as I have been told the bell housing pattern is the same and both are carby motors
    is it straight forward and what has to be changed
    also how much power loss is involved
    any help appreciated before I commit to engine purchase
    Convictania
    Default Re: 21r to replace tired 22r
    Quote Originally Posted by wiki
    "21R
    The 2-valve SOHC 2.0 L (1972 cc) 21R was produced from 1978 through 1987.
    Cylinder bore was 84 mm (3.31 in) and stroke was 89 mm (3.5 in).
    Output in 1978, constrained by emissions, was 105 hp (78 kW) at 5200 rpm and 116 ft·lbf (157 N·m) at 3600 rpm. Air injection and California emissions equipment for the 21R-C (1982-1985) dropped power down to 90 hp (67 kW) at 5000 rpm. The air-injected Japanese version, the 21R-U, produced 105 hp (78 kW) at 5200 rpm and 120 ft·lbf (162 N·m) at 3600 rpm but dropped to 101 hp (75 kW) at 5400 rpm and 114 ft·lbf (154 N·m) at 4000 rpm in 1986.
    [edit] 22R
    The 2-valve SOHC 2.4 L (2366 cc) 22R was produced from 1981 through 1995.
    Cylinder bore was 91.9 mm (3.62 in) and stroke was 88.9 mm (3.5 in).
    Initial output was 97 hp (72 kW) at 4800 rpm and 129 ft·lbf (174 N·m) at 2800 rpm.
    By 1990 the 22R was producing 108 hp (81 kW) at 5000 rpm and 138 ft·lbf (187 N·m) at 3400 rpm.
    The first fuel injected 22R-E engines appeared in August 1982.
    Output of these engines is commonly rated at 105 hp (78 kW) at 4800 rpm and 137 ft·lbf (185 N·m) at 2800 rpm."
    http://en.wikipedia.org/wiki/Toyota_R_engine
    Aug 2009
    south australia
    so the power seesm to be approx the same but I am still after information about how straight a swap it is
    Convictania
  1. Hilux 22R to 22RE Conversion Help needed
    By MrBags in forum Tech and Conversions
    Last Post: 09-03-2013, 12:38 PM
  2. 3RZFE engine to replace 22R engine in 95 model hilux ute
    By Luxmod in forum Engine & Driveline Conversions
    Last Post: 25-06-2008, 09:00 AM
  3. Replacing a Coaster's 22R with 1GGTE
    Last Post: 19-04-2008, 10:03 PM
  4. 3RZFE engine to replace 22R engine in 95 model hilux ute
    Last Post: 10-04-2008, 09:21 PM
