Results 16 to 21 of 21
Thread: find my ignition coil
    Equipped with Bowls Hat Backyard Mechanic Adam_Cressi's Avatar
    Default Re: find my ignition coil
    No Problem
    2JZ-GTE MX-83 Cressida
    Toymods Car Club Club Member # 185
    Quote Originally Posted by ace
    Yeah theres not really a coil plug on the dizzy cap, bloody FWD cars!!! arghh
    I think you're talking about the windcreen wiper motor
    Haha - I am teh lose
    is firing on all eight. Carport Converter AndyTTR's Avatar
    I'm pretty sure the coil is integrated with the distributor. A lot of FE series engines are set up like that. The terminals for the coil should be in that fat plug that plugs in the bottom. Alternatively try the '-Ig' terminal in your diagnosis connector instead of connecting directly to the coil?
    Selangor
    Your coil is quite likely built inside the distributor,
    with a standard vacuum advance. Only four leads
    coming out from the cap confirms this. It's usually
    a transformer-type coil, since an oil-filled coil
    obviously is too big.
    Later model Japanese engines, usually those
    made after the mid-90's, such as the Mitsubishi
    ones in the Proton Sagas in Malaysia, typically
    have a "three-in-one" type of distributor, i.e.
    with the ignitor, coil and electronic advance
    built inside. In more expensive cars, the electronic
    advance is regulated by the engine management
    computer, I think.
    Tasmania
    It most definitly is inside the dizzy thats why you cant see it on the outside.
    cheers Brett.
    Offline Grease Monkey Toycrash's Avatar
    Finland
    It IS inside your dizzy cap... I wonder how long you ppl will debate on this. Just look inside and you can see it truelly is there
    Old toys for old boys
  1. 1jz ignition
    Last Post: 04-07-2010, 08:25 PM
  2. Coil for High Energy Ignition
    By Tham in forum Tech and Conversions
    Last Post: 24-05-2006, 12:29 AM
