Results 16 to 20 of 20
Thread: RA23 ignition issues
    Default Re: RA23 ignition issues
    Lemme make sure I understand the symptoms. Drives fine, then all of a sudden the engine dies and the tacho cuts out. Then there is only 3v at the coil +
    Does it then crank, and just refuse to fire?
    I'm surprised that when u connect the that wire from + battery post to coil + it doesn't fix the problem. Does it give you 12v at the coil +? I would expect so. But the engine still won't fire?
    Check ur points as well. Make sure they are gapped right, and take out the condensor coil to make sure it isn't shoorting to ground.
    They'd be the first checks I'd do.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    Mystery solved, it was the tacho shorting out the coil. Take out the tacho wire and it started like a bought one. Many thanks to all who gave advice. Merry Christmas chaps.
    Yes the old Celica's are great cars thanks..
    76 RA23 18RG
    85 GSXR 750 05 GSXR 750 77 RD400
    So it was the tacho itself causing the issue, or the wire running to it shorting out somewhere?
    Just asking as a friend is having issues with the points burning out, and its been suggested that its being caused by a bad tacho too.
    Thought the tacho going "bad" and causing such problems would be rather unlikely.
    It was the tacho feed wire that goes to the -ve on the coil.
    Points burning out would either be the ballast resistor or the condenser.
    76 RA23 18RG
    Yeah, thats what we figured too, but hes swapped out both of those for good ones a couple of times.
    ... unless he is running the coil on 12v all the time.
  1. Converting to a Bosch Ignition Module (Reluctor Dizzys)
    By RA35GT in forum Tech and Conversions
    Last Post: 03-08-2012, 10:22 PM
  2. 1JZ problems, wont rev, Please help ASAP!
    By ReQuieM in forum Tech and Conversions
    Last Post: 11-07-2007, 02:54 PM
