Results 16 to 23 of 23
Thread: Too much timing (cant back off any more) 5s-fe
    Default Re: Too much timing (cant back off any more) 5s-fe
    engine-off test for slipped harmonic balancer: put mark on crank pulley at #1 TDC, remove #1 plug and place long screw-driver (or other thin rod) down plug hole, rotate crank thru TDC and check that mark is at 0 when screw-driver/rod is at max height.
    Sounds like he has already done that ^^^^.
    Are you sure you are putting it into diagnostics mode?
    When you bridge Te1 & E1, does the idle move up or down, engine change note, etc?
    What is the timing sitting at when at idle and not in diag mode?
    Tasmania
    yep my bad, with the aid of a mirror i could see it was a tooth off, meaning it was a tooth off when the guy got the car.
    who feels like a fool...i do
    1973 TA22
    Brisbane
    it was never going to be anything else
    Tasmania
    lol yeah logic suggested.
    1973 TA22
    Brisbane
    I'm guilty of that too - trying to find a complicated way for something to be wrong, when there's probably a simple answer.
    Tasmania
    i duno whos idea it was to use a hole in the cam gear aligning with a groove in the bearing cap, its not the best IMO. Neither is it being down next to the tower where its hard to see properly even with a mirror.
    1973 TA22
    Oct 2008
    TAS
    east west engines fails every time for annoyance. good to see you sorted it out tho!.
    1983 Toyota Celica Supra
  1. 2JZGTE VVTi Timing Belt Installation, Help needed!
    Last Post: 20-11-2008, 04:05 PM
  2. 3sgte timing belt issues st185
    By danny2 in forum Tech and Conversions
    Last Post: 19-02-2008, 06:20 AM
  3. 1g-gte Piggy Back Options
    By Z2TT in forum Tech and Conversions
    Last Post: 13-12-2007, 09:18 AM
  4. Crank timing pulley timing belt guide, fixed or spinning?
    By Howieau in forum Tech and Conversions
    Last Post: 27-09-2007, 06:06 PM
