Results 1 to 12 of 12
Thread: 1jz cold start problem
    Junior Member Grease Monkey chaserbuddy's Avatar
    Feb 2008
    Default 1jz cold start problem
    hey
    I have a 1jz out of a jzx90 fitted into an mx83 and it has trouble starting in the mornings or when cold. I have noticed that the colder the weather is the harder it is to start. It turns over fine and will eventually start and splutter for a few seconds and then die, Also as soon as I press the accelerator it will kill it. I have to start it up again and leave it idling for a while and the rpm will eventually rise up from around 500 as it gets warmer. Generally it takes a couple of minutes for it to warm up enough to drive. Once its warmed up there are no problems at all and it runs fine. Things I have done so far are check that the fuel is priming which it is, cleaned the iscv, replaced the water temp sensor for the ecu, replaced the air temp sensor. and pulled codes, 1, 2 twice(not sure if that means 22 or 2 as it flashes twice with a 2.5sec pause and then another two times),4,7 and 8.
    If anyone has any idea of what may be wrong with it please let me know.
    Also if anyone has a auto jzz30 or jzx90 ecu that I could try to help eliminate the ecu as the problem that would be great.
    Thanks
    May 2007
    Default Re: 1jz cold start problem
    I think i have a jzx90 ecu but am not sure... definately some variant of 1jz auto ecu...
    is the IACV actually opening on startup?
    Feb 2008
    Quote Originally Posted by midnight_purple_GA70 View Post
    there is power to it, so i assume its doing its job, I did swap it over from a running 1jz so it's probably not that. Hopefully someone has one locally so I can check rather than having to purchase one from interstate. I'll let you know if I require it thanks.
    What heat range are the plugs that are installed?
    A 1J I got from japan once had a set of cold HKS plugs in it which started OK in summer in Brisbane, but once it got to winter it was a real pain to cold-start. Replaced them with Denso PK20R11's and it started fine when cold.
    Feb 2008
    Quote Originally Posted by JP View Post
    I'll look at that, haven't looked at the spark plugs yet, Also I sprayed some start ya bastard into the intake and it fired first shot and then died once the vapors were used up. I'm really not too sure whats happening it seems as though the ecu isn't putting enough fuel in on cold start. thanks for your input
    May 2007
    Quote Originally Posted by chaserbuddy View Post
    try disconnecting the breather hose off the back of it and blocking off the turbo side...
    you will hear a very loud suction noise from the IACV if it works if you dont then somewhere in the wiring a fault has come about... or a sensor is playing up with something etc...
    First think I'd be doing is sorting out the check engine codes
    Is it possible that you may have codes 22, 24 and 78?
    22 = Water Temp Sensor
    24 = Air Temp Sensor
    78 = Fuel Pump Control
    I'd be checking the resistance values of the Water Temp Sensor and the Air Temp Sensor at the engine ECU plugs with the engine ECU unplugged to make sure the wiring in the loom and the sensors are OK
    Wilbo's JZA80
    Wilbo's JZZ12
    Feb 2008
    Quote Originally Posted by wilbo666 View Post
    I suppose it is possible, As I haven't had much experience in checking codes. thanks Wilbo I will check the sensors and wiring again.
    Feb 2008
    had a look at the wiring again and I noticed that someone had wired the temperature gauge off the water temperature input to the ecu also having known that the dash temp gauge has its own thermostat the wiring was incorrect. Makes sense as the current and voltage to the ecu will have been reduced and therefore changed the predicted water temperature. Problem is now fixed. thanks for everyone that contributed.
    You must spread some Reputation around before giving it to wilbo666 again.
    Good to hear you fixed it!
    Wilbo's JZA80
    Wilbo's JZZ12
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    That would of been me!
    My bad, glad you fixed it mate. All running now?
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
    Feb 2008
    Quote Originally Posted by Hengsta View Post
    yeah no problems now, starts first go every time and runs well.
  1. Cold Start Switch - Where to buy?
    By 88AW11SC in forum Tech and Conversions
    Last Post: 07-09-2008, 01:48 PM
  2. Strange Noise on Cold Start
    By FRK-16V in forum Tech and Conversions
    Last Post: 05-08-2008, 02:21 PM
  3. 1jz idle problem
    By ms53wagon in forum Tech and Conversions
    Last Post: 05-07-2008, 08:43 AM
  4. omfg. 1g problem has carried over to 1jz after conversion :(
    By pato in forum Tech and Conversions
    Last Post: 03-08-2007, 07:19 AM
  5. 1JZ miss fire/Electrical problem
    By tyottsoarer in forum Tech and Conversions
    Last Post: 27-08-2006, 05:46 PM
