Page 56 of 74 FirstFirst ... 646545556575866 ... LastLast
Results 826 to 840 of 1105
Thread: The 18R-GTE reference manual ...
  1. #826
    Brisbane
    Default Re: The 18R-GTE reference manual ...
    Quote Originally Posted by o_man_ra23 View Post
    Your question wasn't if there were any dyno sheets done in the last week. While 150RWKW isn't 2JZ territory, it is quite substantial, especially for a conservative run in tune. So in answer to your other wondering, yes, people have got plenty of power out of them.
    Must be a slow day at your end
  2. #827
    Frustrating day... I get upset when things which you pay a shitload of money for don't work how they are supposed to...
  3. #828
    Brisbane
    worse again here, i paid a shtload for somethign that didn't even turn up
  4. #829
    Does it cost more than the average annual wage for every day that it hasn't turned up??
  5. #830
    Brisbane
    hm, not that much, but $250 out of pocket is enough to peace me orf!
  6. #831
    I asked this question in the CCDT, however the majority of feedback involved standard motors. So... what's a good 100kph cruising RPM for the 18R-GTE?? River seems to like 2600@110kph. From my calcs 2700rpm at 110kph translates to using a W58, 3.73:1 diff, and 225/50/16 tyres (though River seems to have done his with 4.1:1 diff gears??)
    Motor specs are 92mm Arias forged 8.5:1 pistons, balanced to the billyo, lightweight flywheel, stock 18R-GUE cams, 18R-GUE head (very mild porting, stock intake manifold), CT26 huffer. Pre-bottom end implosion when I had 8.3:1 88.5mm pistons with stock flywheel and no balancing, the torque seemed to come on nicely around 2500, with noticeable boost at about 2800rpm. I would expect with good tuning and the new bottom end specs, that torque RPM will drop down further. So would a 2400rpm 100kph cruising speed sound good??
  7. #832
    probably going to be a hard question till you get ur engine dyno'd. Find out what the torque curve is like. Also, why the concern with what revs it should be running at? If you wanna accelerate just knock kit back to third n floor it
    I don't know what the 1j has at 100k, but i wish i had a 6th gear. Has a w58 gearbox and hilux 4.11 diff.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  8. #833
    My turbo (GT25R) is starting to sing at 2600rpm, so when in 5th gear at 110kph there's no need to drop it down to 4th as she picks up just beautifully. Of course, if you want to really haul arse then sure, drop her into 4th.
    The whole point of my build with Trini was for her to be fun and very nimble, as most of her time will be in suburban traffic. The 4.1 diff and the small turbo (with no lag) means she flies off the mark and accelerates like a demon. I chose the W58 purely because it had that long 5th gear, which is for those time when I am cruising the highway.
    seeyuzz
    river
  9. #834
    Junior Member Grease Monkey MnToyGuy's Avatar
    Minnesota
    I emailed my pump guy last week and look at the response:
    "I had it pumping parts wash fluid for 5 or 10 minutes.
    So I think it is close….I would recommend pumping oil with it for at least a few hours before putting it in a motor but, that would be your call.
    When shall we get together."
    Toysport even expressed interest in testing the pump! I couldn't ask for better. I should at least have some updates
  10. #835
    This news is good. Me Rikey...
  11. #836
    Minnesota
    Meeting the guy for lunch tomorrow, and shipping it off to Toysport for eval!! Woo Hoo. For those of you who don't aren't familiar with them, they were basically TRD USA before Toyota came in direct. They still have a lot of contact with Toyota, so they are going to try to find out the hardness information for the stock components.
  12. #837
    Cool, i'm still on the 'interested parties' list
    Junior Member Backyard Mechanic Rhyno's Avatar
    Jan 2010
    NT
    Great news! Im still interested as well
  14. #839
    Minnesota
    Pump is on its way to Toysport!!
  15. #840
    Aug 2010
    S.E.Q.
    What are you going to test it in. Some smokey old corona, or stick it in the good car ?
    Owen.
  1. GUIDE - 85amp EA Falcon Alternator onto 18R or T series engines
    Last Post: 03-05-2019, 05:25 PM
  2. 18r need to align cams/timing marks
    By Quinn in forum Tech and Conversions
    Last Post: 03-05-2006, 11:00 AM
