Results 16 to 24 of 24
Thread: 2005+ Hilux diff centre into RN85
    wa
    Default Re: 2005+ Hilux diff centre into RN85
    Dont forget you will need to change the rear flange plate on your tailshaft to the new hilux one.
    The uni's should be the same diameter anyway so it should be a straight swap.
    Add Lightness! Grease Monkey spectral's Avatar
    can you not just bolt the diff flange from the RN85/90 to the nose of the KUN26R diff centre?
    Westfield Clubman SEi - 4AGE Blacktop, T50
    RN90R Hilux XtraCab - VT V6 (yeah yeah) ,4L60-E, 3.583 LSD
    wa
    No it wont work its a different seal diameter unless you change the seal which we couldnt be bothered so we just changed the rear uni flange
    Thanks again... well thats a bugger, another trip to the wreckers will be needed.
    Jan 2008
    queensland
    Quote Originally Posted by 50RTD View Post
    I've got a brand new (i.e like 14km....) LSD Hilux centre if anyone is interested.....
    Cool, what ratio? or is just the lsd centre assy- either or how much you chasin for it?
    Junior Member Grease Monkey 50RTD's Avatar
    May 2009
    Yeah its the centre only Mick, so will need to be put into a pumpkin. Has done literally 14km, went straight to ARB for a locker fitment so is brand new. After around the $350 mark.
    Regarding the ratio's, you can buy brand new crownwheel and pinion stuff from 4x4 suppliers, such as Terrain Tamer and a few others. Gives a bit of freedom to select ratio's, providing you know what you're after. If i recall correctly, a crownwheel/pinion set is around the $500 mark...
    http://www.terraintamer.com/catalog/...omponents.html
    The other consideration is that Toyota LSD's are fairly average after a few km as the clutch packs wear out. I wouldnt be banking on whacking a 200,000km wrecker diff in and leaving number 11's on the road..... more often than not will be a dirty big number 1!
    Quote Originally Posted by spectral View Post
    - 2005+ 4x4 Manual - 3.583:1. LSD. Both petrol and diesel same ratio. Wreckers want $450, but I got mine on ebay for $255 this week.
    - 2005+ 2WD V6 and Turbo Diesel (not 4cyl petrol) - 3.583:1. non-LSD, but was an option.. Haven't seen one at the wreckers
    Any suggestion for what wreckers ask those kinds of prices? I called a couple of 4WD wreckers today in Sydney and they wanted $650 for an open centre.
    Sure, the guy at the Minden 4WD wreckers (about 1hr west of Brisbane) quoted me on the LSD 3.583 about 6 months ago, but I thought it was too much It was still in the vehicle at the time. I'm going past there on Friday if you want me to stop in and check if its still there and what price..
    Maybe the "phone" price is inflated ... or maybe the Sydney metro wreckers are more expensive compared to regional QLD where it is Toyota 4WD country.
    $650 sounds so exxy for an open centre What are they asking for LSD?? $800?? Cripes, I might sell mine and use the profits to pay for the engine conversion
    EDIT: Actually -=Lance=- (Richard) lives not far from there, and I know he has a good relationship with the guys at the Minden from his Hilux days before being a traitor and buying a rotary.. maybe he can wrangle a better price?
    Just an update on this, 1 or 2 weeks turned into 1 or 2 months, you know how it goes.
    All bolted in fine with the noted (as above) exception of the front flange which I redrilled to suit the RN85/RN90 tailshaft. The tailshaft has a concentric locating ring on it anyway, so you can't really go wrong there unless you are hamfisted with marking and drilling.
    The diff was a bit noisy, so unfortunately had to put a bearing kit through it in the end.
    Otherwise no dramas at all... and no embarrasing 1WD slithers at the traffic lights any more
  1. Hilux diff centre in A70 supra housing
    By zolpix in forum Tech and Conversions
    Last Post: 07-10-2010, 04:32 PM
  2. Hilux G series Diff Conversion
    By auto351 in forum Tech and Conversions
    Last Post: 23-02-2008, 04:51 PM
  3. Current model Hilux diff observation.
    By MacroP in forum Tech and Conversions
    Last Post: 30-08-2006, 04:49 PM
