Results 16 to 22 of 22
Thread: ABS issue with JZA70 using MA70 bits
    May 2008
    Default Re: ABS issue with JZA70 using MA70 bits
    you could be right as I know my speedo is 10kms out doing 50 = 60ish. arghh might just bugger it off its working fine with the abs disconnected. will check it out now!
    1992 - JZA70 STOCK - SOLD
    May 2008
    ok did some checks unplugged rear speed sensor now something strange put my test leads across RR - and RR+ going to ecu with it unplugged from JZ loom and im getting continueity across them is that ment to be seems incorrect
    is firing on all eight. Carport Converter AndyTTR's Avatar
    Does that 'B3' plug only go to the sensor, or is it one of those big car harness to engine harness plugs?
    It's possible to get small amounts of continuity between the + and - as the power supply to the sensors is usually shared... it shouldn't be 100% continuity though.
    I'd check the continuity from the plug at the sensor to the plug at the ECU with all your intermediate connections left as-is. If it's no good, check it from that intermediate plug - that'll tell you which side of the intermediate plug the problem is on.
    Does the speed sensor have 3 pins or 4 pins? If 3, where did the 4th wire for 'ECT' go?
    Speed sensor are 3 wire units.
    Power, earth, signal.
    If you have any of these backwards, she will not work.
    Also if the sensor is stuffed, she obviously won't work.
    My setup was a W5x wired into an ABS unit which was originally for an A340E.
    May 2008
    im guessing stuffed sensor now tried everything you guys ive checked and wiring is correct. from sensor its wires RED = PSEN, Black = RR- White = RR+ then from its plug its going to the abs plug in engine bay to Yellow = RR-, Black = RR+ and RED/black = Psen. might get a new sensor from drift motion and give that a shot.
    thanks guys
    I'm pretty sure the UZS131 Crown ABS sensor is the same, thats what I used.
    May 2008
    ok something wierd. went for a long drive and noticed that the light was off... noticed sometimes it would come and go. for awhile it was gone....came to a intersection started to slow down turned bend and boosted up and light came on and stayed on still I re started it... any time the light was on it was code 33 rear wheel sensor!
  1. MA70 --> JZA70 Conversion
