Results 1 to 4 of 4
Thread: clarification needed on trans fluid - jzx100 a341e
    south australia
    Default clarification needed on trans fluid - jzx100 a341e
    Yo,
    I am about to do a trans service on my chaser. I have filter and 12 litres of fluid.
    Now, the local toyota dealership has given me T-IV BUT, on the dipstick it states TIII.
    Are the two interchangeable?
    I come from a holden dealership background, we use dex 3 and dex 6.......dex 3 is not interchangeable with dex 6, this is why i am concerned about toyotas trans fluid.
    Junior Member Grease Monkey twiztd's Avatar
    Aug 2006
    Default Re: clarification needed on trans fluid - jzx100 a341e
    T-IV is backwards compatible to T-II and T-III. Have sighted the Toyota service bulletin that says so...
    Now - 1988 GX81 Mark II- 7MGTE, GT35R, TiAL 44m, Microtech, 550cc injectors, R154, Xtreme clutch, LSD.... Low boost tune done = 330rwhp@1 BAR...
    Then - 1989 MX83 - The big scrap heap in the sky...
    I used T-IV in my cressy a340e-a341e hybrid
    May 2010
    Moscow
    Only ensure you don't mix the two. I use T-4 in my JZX100 A340E. Note that unscrewing gearbox sump is not sufficient to let the old fluid out completely, sensible amount of it would still be there.
  1. Shift issues with A341E auto trans
    By skyther in forum Tech and Conversions
    Last Post: 29-09-2010, 01:37 AM
  2. Auto Fluid Change - A341E - Part Numbers?!
    Last Post: 31-05-2010, 12:06 PM
  3. LS400/1UZ-FE auto trans fluid amount
    By dori dori in forum Tech and Conversions
    Last Post: 18-11-2008, 08:52 AM
  4. A340 trans fluid level...
    By SL666 in forum Tech and Conversions
    Last Post: 15-02-2006, 06:24 AM
