Results 1 to 6 of 6
Thread: 3SGE Clutch (Torque) Settings
    Junior Member Backyard Mechanic Rhyno's Avatar
    Jan 2010
    NT
    Default 3SGE Clutch (Torque) Settings
    Hiya!,
    Im a noob to this website but fairly mechanicaly minded (I'm a Fridgey), and the story goe's I broke my daily driver, waterpump shat itself doing a 100km/h = warped head, 300,000 kms, not worth the buggering around
    So I have bit the bullet and binned the 3SFE and grabbed a 3SGE, a wiring loom and ecu a mate had laying around.
    Just having a little trouble trying to find out the torque settings for the clutch on the GE. I have tried searching, and searching this forum, and also googled like crazy... So if you can point me in the right direction that woud be great.
    I am using an aftermarket "sports" clutch that I got with the engine. I know its rated to 300hp and looks just like a standard one, but f@#k knows what brand it its. The car is a SV21 Carmy, the gearbox is the 5 speed manual that came with the Camry. The GE is the first generation, out of a ST162 Celica.
    The thought of using the standard torque settings for the standard clutch on the GE had crossed my mind, since im using the standard GE flywheel...
    If any one knows the setting or could point me in the right direction I would be very appreciative. Thanks for reading!
    Default Re: 3SGE Clutch (Torque) Settings
    I had some issues getting it to work for me. But you might be able to have the whole engine manual here:
    http://www.celicagt.nl/Docs/st202_rm396e.pdf
    got it to work
    torque: 107 Nm or 79 ft-lb
    page 171
    that sounds way too high for the clutch pressure plate bolts to flywheel. sounds more like the flywheel bolt torque...
    If you have the factory bolts, then use the charts on page 12 and 13.
    Jan 2010
    NT
    Smile Re: 3SGE Clutch (Torque) Settings
    Thanks guys,
    I was after the clutch setting, but the tables on this pdf should do the job, also a stack of other useful information...
    Didn't know you could get these with an oil cooler fitting plumbed in, I was just going to put a t piece at the pressure switch with an el-cheap-o autobarn inline cooler. Have to start searching again haha
    How do I + rep you guys?
    Thanks again!
    Ryan
    For Gen 2/3 3sgte, we use
    Clutch Cover
    195kg-cm, 14ft-lb, 19Nm
    for the pressure plate which was taken from the toyota manual.
  1. 18RG Torque Settings??
    By ganador in forum Tech and Conversions
    Last Post: 22-01-2012, 08:39 AM
  2. torque settings for clutch for 18rg
    By sexybackra28 in forum Tech and Conversions
    Last Post: 12-07-2009, 10:45 AM
  3. Gen2 3sge torque settings
    By StuC in forum Tech and Conversions
    Last Post: 24-08-2006, 08:48 AM
