Results 1 to 10 of 10
Thread: sr20 into a sa63 celica
    Jul 2008
    Default sr20 into a sa63 celica
    Hey Guys
    Thinking about dropping an sr20det into my sa63 celica has anyone on here done it how much in evolved with engine mounts drive shafts ect
    any help would be great
    Thanks
    Toby
    Default Re: sr20 into a sa63 celica
    seeing as it already as the S-mounts and such would it not be easier just to throw a 3S in there?
    Each to their own in how that wish to treat their car, but it just seemed like a no-brainer to me.
    Jul 2008
    yer ive thought about that, but the price factor thats all, i can get an sr20 alot cheaper than a 3s, dnt get me wrong i would love a 3sgte
    the cost of a conversion much more then the cost of an engine... you have to think about all the fabrication work that is needed to get the engine to sit in the chassis correctly. In the end you will probably find the overall cost difference of the 2 different engine conversions to be negligable...
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    Also factor in swapping in an F series diff out of an RA65, because the T series isn't likely to last very long behind an SR20.
    Some of the things that would also need attention:
    - Engine/gearbox mounts
    - Possible sump modifications to clear crossmember
    - Tailshaft
    - Exhaust
    - Fuel tank and fuel pump
    - Transmission tunnel modifications to account for the different shifter positions
    - Wiring
    Then add to that any other minor issues that pop up. Also, if you haven't already done so, adequate suspension upgrades are probably not a bad idea. Standard brakes aren't too bad, but if you intend to be braking hard a lot, then an upgrade there is probably also warranted.
    By all means though, go for it. It'd make for a nicer driving car than the 2S and still be a lot more individual than the multitude of Silvias and Skylines getting around. Just be aware of all the other bits and pieces that need to be modified to get everything running. Do as much research by yourself as you can and ask for help with more specific questions when the need arises.
    May 2006
    $2000 for a complete Beams 3S swap these days - $3000 if you want the 6 speed. Spewing they weren't that cheap when I started my Gen2 conversion. No offense intended but you'd be nuts not to do an S conversion when the motor will just bolt in. Getting everything right is a big job and toyota has already done everything for you.
    May 2006
    tas
    SR20 a workhorse unit. if you would want to do anything competitive then the SR would probably be the better option. Id probably go for a 3S though. forget about gen gen 1/2 na 3S waste of time (unless you only want a shitter daily driver), either a beams 3s or gte.
    but to answer your question, would be much like the conversion into a ke70 etc except you have more room.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Junior Member Backyard Mechanic MOOKIE's Avatar
    tas
    Hey mate I'm looking to do the exact same conversion, altho I'm aiming to mount the motor back as far as I can, in a perfect world the whole thing will be behind it, I'm planning on using an s13 x member suspension and steering up the front
    how different are the cross members on the AE86 compared to the SA63? As far as i was told the SR20's vertually bolt into the AE86. Could you use the AE86 X-member in your SA63 with minimal mods?
    inside of me is screaming out beams though... but each to their own
    Oct 2010
    queensland
    Hye mate.
    I have done the sr20 with 5 speed convertion into a ra28.
    One of the bellhousing mobs do a sr20 to w58( i think) kit.
    I would have done the 3s conv. too but the costs of the engine was as much as the motor/gbox combo i brought.
    I can get you a sr20det redtop with 5 speed, clutch wiring loom and comp. About $2600
    Well thats my thought and pictures at
    http://4ccustomclassiccelicaclub.webstarts.com
    Come and have a look.
    Cheers Craig
  1. Replies: 308
    Last Post: 09-06-2009, 02:22 PM
