Results 1 to 9 of 9
Thread: Help with type / heat range PLUGS for 3SGTE ENGINE
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Post Help with type / heat range PLUGS for 3SGTE ENGINE
    I have tried some Iridium Bosche
    with 0.8 gap but they fluff and miss under load when boost kicks in.
    Going back to NGK if I can source.
    Anyone got a parts range please and heat range.
    Has anyone tried the dual electrode plug specified for the 5SFE 3SGE?
    What plug leads do you use?
    Has anyone swapped to plug packs and thrown the dizzy out like on late 3SFE?
    And the 4A 3TGTE modifications.
    NGK is a BKPR platinum series, or BKEI Iridium series.
    Maybe a dash 8 heat?
    Anyone tried any other types at what boost and what results thanks.
    and a good source/price maybe under the retail $20 price?
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
    Default Re: Help with type / heat range PLUGS for 3SGTE ENGINE
    8 is pretty cold.
    how much boost are you trying to run? 20-25psi?
    most NGK sites have plug finders
    NGK BKR7E is the plug to use on stock to ~20psi 3S IMO
    They are just a simple and cheap copper plug but I have had to get them ordered in specially from repco or supercheap as they dont stock them in my experience.
    Their naming convention updated the NGK part number from 6097 to 4644 (v-power) if you have trouble there.
    Apr 2010
    NGK's in the 7 range would be perfect.
    Even the standard plugs should work fine.
    stock for caldina 3SGTE is PK20R8 or BKR6EP-8
    supposed to last 100Kkm
    Default FOUND PLUGS for 3SGTE ENGINE
    Quote Originally Posted by oldcorollas View Post
    Thanks
    Put in some BKREP-6 worked fine
    returned the Bosche they were for 5SFE.
    wa
    i thought the 5sfe had a 1.1mm gap?
    but yeh i just use BKR6E the ones with v groove. they shgould come with the 0.8gap, but if you find they still miss with high boost you can gap them down a tad.
    or get a HKS ign booster thingo, they seem to work very well.
    Default Re: FOUND PLUGS for 3SGTE ENGINE
    Quote Originally Posted by RT104GT View Post
    Thanks
    why did you buy the wrong (expensive) plugs?
    Jun 2009
    yeh 5sfe is indeed 1.1 gap. that would explain the missing. i havent heard of any people running 8s but 7s work great even with high boost.. i bought NGK iridium 7s and work fine. 7s gapped down get used in cars with 350whp and work fine should have a prob
    90' GT-Four ST185 RC motor ST205 gearbox!
    New installs Ct20B and Rear Strut Brace!!
    Next to come;
    3SGE cams, Fidanza Adj Cams, WolfKatz fuel rail!!
  1. Turbos 101
    Last Post: 24-01-2007, 07:23 PM
  2. Cooling Systems - Overheating Problems.
  3. Guide: Removing paint from plastic parts (more input needed)
    Last Post: 13-04-2006, 01:09 PM
