Results 1 to 5 of 5
Thread: buying w85 - how to tell if its in good cond?
    Apr 2010
    Default buying w85 - how to tell if its in good cond?
    Hey fellas like the title says, Im thinking i may need to replace the box in my hilux. There is a guy on boostcruising with one 4 sale for $400. Seems pretty cheap, anyway is there anyway to tell if its good or not when not in the car?
    Default Re: buying w85 - how to tell if its in good cond?
    -check the oil stuck to the filler plug (for excessive amounts of metal - there will be some)
    -rear seal condition
    -put into gears and feel for excessive backlash between input & output shaft)
    -count input/output ratio on 1st & 5th (to confirm is W58)
    -play on shifter bush
    -what was it behind (if 2JZ then may have had a hardlife)
    -smell the oil (for age or if has been too hot, will smell like burnt diff oil)
    3RZFE-T Backyard Mechanic
    Nov 2008
    queensland
    note: a w56 or a w55 will no work in place of a w58
    Apr 2010
    THanks 4 the tips fellas!
    Quote Originally Posted by Tweak View Post
    huh?
    W55, W57 or W58 are mostly identical (except for shifter positions) - the differences are noted in this thread.
    W56 is a truck gearbox (ratio wise and there can be differences in the rear snout) but will bolt up in place the others mentioned above.
