Results 1 to 13 of 13
Thread: piston ring question
    Genuine Hotty. Conversion King old_mr2's Avatar
    Default piston ring question
    Hi
    4agze motor (bigport)
    2 compression rings. 1 is dead square (1.5mm) and the other has a circle mark and a angled inside edge (1.5mm).
    Which one goes in the top ring groove, and which one goes in the bottom?
    Thank you!
    Default Re: piston ring question
    Hi
    All fixed, found out the angled ring goes on the bottom. The rings are Hastings. Cheers.
    Where did you get them?
    from Wiso mate.
    pfft I mentioned that to you when I let you know I sent them bottom one has dot facing up
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    Quote Originally Posted by wiso View Post
    Yeah I know, see post #2
    Is that to say that wiso has connections? I need some odd-sized rings...
    -rm
    Have a look through the hastings website for the sizes that you want.
    Their online catalogue is very good and can be searched in so many ways.
    Precision International are a supplier for most auto stores and also stock hastings stuff.
    www.hastingsmfg.com
    (\__/)
    (")_(")
    Quote Originally Posted by mullett View Post
    -rm
    No connections, the guy who did my engine ordered me the wrong ones, I had smallport pistons, he ordered me bigport ones, and since I had already put on the oil rings, no refund
    89' MR2 AW11... His
    How come you had to pay for his mistake?
    May 2006
    Time to go in there guns blazing mate. If you asked for a product and they gave you the wrong one they're in the wrong. Unless you didn't specify what motor you had I'd be wanting a replacement.
    the motor was out of an aw11 so thats what he looked up even though I told him I had ae92 corolla pistons, he rang and said they listed the same type so he said order them I said ok, then I looked into it after the fact when I had already put the oil ring on and went to put the compression ring on.
    fact is the guy did everything hell cheap because he didn't write receipts, so I really didn't have much of a leg to stand on.
    89' MR2 AW11... His
    May 2006
    I guess you can mix and match the sets and try and sell the other set off at your loss... or get him to order the right rings under the guise that your paying for them. When you pick em up with 3 of your biggest mates throw the old ones on the table and thank him for doing the right thing and replacing the incorrect part that he ordered by accident. Companies like this should be shut down IMO - if they think they can walk over you they will.
    Last Post: 29-02-2016, 12:30 PM
  2. 22R piston dimensions
    By joecoolmk2 in forum Tech and Conversions
    Last Post: 03-10-2009, 11:53 AM
  3. Filing piston ring gaps
    By ra_28 in forum Tech and Conversions
    Last Post: 08-07-2008, 09:56 PM
  4. confusion over acl/mahle piston specs
    Last Post: 26-03-2008, 01:01 PM
