there is a difference
GTE pump moves greater volume per rotation
which is shown with the ~4mm difference in height of the internal gears (pump bit)
http://www.mkiiitech.com/forum/showthread.php?t=356
^^ as discussed here
you can do it, but would probably suggest you dont
the difference in volume is due to the need to supply oil squirters, turbo, and oil cooler which is pressure activated not temp and returns directly to sump without going through rest of oiling system
