Results 1 to 15 of 21
Thread: Wastegate Shaft lubricant
    Default Wastegate Shaft lubricant
    The shaft on my wastegate (Tial 46mm) is sticking. I need to lubricate it with something but i Haven't the faintest idea WHAT to lubricate it with given the heat of the area..
    anyone got any ideas?
    Facebook | LinkedIn
    Default Re: Wastegate Shaft lubricant
    graphite? is the shaft bent?
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    nope, no shaft bent. just out of lube.
    Facebook | LinkedIn
    I would try some sort of peneration lubericant like penatrene or chemsearch yeld or even C.R.C. there's not much that will stand all that heat.
    Alex
    crc will burn off in two seconds flat mate. :-) But thanks for the thought all the same.
    Facebook | LinkedIn
    Would it be sticking due to exhaust build up on it? Would cleaning help?
    - LeeRoy
    maybe it just needs a good clean?
    User Conversion King
    NWA
    nickel based grease (aka.nickel anit-seize) is the best for VERY high temperature lubrication. i use it on all my exhaust bolts, sometimes spark plugs.
    it pracially impossible to burn it off anything
    its looks a thick metallic paint.
    hello
    S.A
    STRADLATER :
    Off subject . How long have you had the gate ? Are you happy with it?
    Im about to buy a 44mm one is this sticky wastegate issue a prob with all Tial gates?
    Quote Originally Posted by brett_celicacoupe
    i secound this! the copper and nickle in it are the main parts that last in the heat!
    i use it on everything! when i undo something it goes back on with copper anti seize! makes life much easyer.
    yeah, the nickle stuff sounds the goods. ah well, it just got wheel bearing grease this time around, buT HELL did it make a difference. THe things a f'ing animal now..
    4A - I dunno if it's common to tial wastegates, but this one has had issues before. First time around, the wastegate actually STUCK open and I got no boost at all. was very annoying. But I'm a master in how to take them apart now
    Facebook | LinkedIn
    S.A
    Thought id dig this thread up as im having trouble with my TIAL 44mm wasegate at the moment. The gate is brand new.
    Im having probs at the moment as it will not open. I have tried everythig even turned off boost controller all together to see if it will open but no go.
    The gate was ordered with the specific spring rate to hold 30 psi boost. At the time i was told by the guy who i ordered it from that with this spring rate i would have a minium boost level of 16 psi which is fine for low boost.
    But at the moment i have the boost cut set at 20 psi and the gate is not opening at all !
    Im wondering if the spring pressure is too high ?? and i should change spings
    Any one had any similar probs ??
    YES it is connected correctly !
    Dreamer Backyard Mechanic millsi's Avatar
    30psi4agte: this is a long shot but did you get your tial off ebay?
    S.A
    No i got it from the U.S direct from tial.
    cool, im looking a getn a tial bov off a guy on ebay for $315. he sells a lot of tial stuff
  1. Replies: 2
    Last Post: 10-03-2009, 04:29 PM
  2. Drive shaft length
    By vtrfirestorm in forum Tech and Conversions
    Last Post: 03-02-2006, 06:15 AM
  3. CT12a Information (shaft play)
    Last Post: 17-10-2005, 06:53 AM
