Hi all,
I have finally got my act together and last weekend fitted a 2jzge to my 86 model
cab chassis 2wd hilux,
I have also since purchased a walbro fuel pump to fit inside the tank,
So here go's with the questions, should i change the fuel fuel tank pick
outlet pipe to an 8mm i.d pipe or will the 6mm i.d pipe be o.k...?
second question is will the standard 2 core hilux radiator be any good for the
2j or should i run a 3 core....? I know a three core will be better but am very limited
for room.
the other option is to run with the supra (jza80) radiator although this is a single
core and much wider, wider than the radiator support so the ends of the radiator
wont get as much air flow......
any advice or previous experience appreciated, thanks.![]()
