Results 46 to 52 of 52
Thread: Autronic SM4 Error - Engine will only crank
  1. #46
    Default Re: Autronic SM4 Error - Engine will only crank
    i tried that once - and got zapped by the lead.
    Not cool.
  2. #47
    just loosen all the leads on the plugs - they'll happily arc over a short gap that's enclosed by the rubber boot. Then move one at a time with the longest/insulated thing within reach.
  3. #48
    Quote Originally Posted by JP View Post
    Ok,
    Another test is to pull the plug lead to each cylinder one by one while it's idling to see if it makes a difference to the running. That's a fairly easy way it identify a cylinder that's not doing it's job.
    We pulled every lead and every injector and they all seemed to make a difference in making the thing run even worse than it actually was.
    There was no one plug or injector that made no difference when removed.
  4. #49
    #2 and #5 injectors when disconnected *seemed* to smooth it out and raise the idle speed.
    Nothing else we did really made a noticable difference.
    Idle is not smooth, and appears to be running on probably 4 cyls.
  5. #50
    it needs a good floggin, thats what it needs.... poor bastard has been sitting there dorment for bloody ages
  6. #51
    There is always 'a good floggin' to be given, however the smell of fuel given the amounts not burning was the worrying factor
  7. #52
    im guessing you have no wideband O2 sensor/gauge to confirm this do you?
    anyway, we can chin wag about it later tonight.
  1. Crank angle sensor position
    Last Post: 30-07-2018, 01:34 PM
  2. 4age Crank Info for 4agte usage
    By dangdang in forum Tech and Conversions
    Last Post: 23-01-2011, 01:00 PM
  3. Forged or Billet 4340 Crank /vs./ Machined OEM Crank
    By Radar in forum Tech and Conversions
    Last Post: 13-09-2009, 03:25 PM
  4. Autronic no spark need help
    Last Post: 03-07-2008, 09:25 PM
  5. Crank Pulley Balance?
    By Talasas in forum Tech and Conversions
    Last Post: 23-10-2007, 02:09 PM
