Results 1 to 6 of 6
Thread: A341 and 5-speed (probably A651) shifting pattern?
    May 2010
    Moscow
    Default A341 and 5-speed (probably A651) shifting pattern?
    Hi All!
    Have received an 1JZ-GTE assembled with a/t for a swap, but until now didn't check it thoroughly. However it turned out that connectors in harness do not fit those on the tranny (marked as 30-41LS). The connector found in engine wiring that mates with solenoid block contains 12 pins. Which means it is for a 5-speed box.
    So I have ECU and wiring for a 5-speed auto and have to (if possible) run the 4-speed device with it. The most obvious and straightforward decision is to convert 4 solenoid control signals into 2, leaving lockup solenoid control intact. And the problem is, I don't know either shifting pattern for further investigation. Could anyone help in obtaining this?
    Sep 2009
    Default Re: A341 and 5-speed (probably A651) shifting pattern?
    To my understanding that the 5spd is totally different to the 4ssd.
    I think an aftermarket auto computer like a suprastick or a PCS auto computer would make it run the 4spd would resolve the shifting pattens as you would adjust/custom to suit your car.
    I have seen the PCS auto computer in action which is quite simple to wire up also have full control of the auto.
    Cheers.
    ZZT231 sent me here
    May 2010
    Moscow
    Once more, what I got now is a *standard 4spd gearbox* and some rare ECU+wiring. According to the ECU's wiring I assume that it is designed for a 5-speed auto.
    So an aftermarket ECU is not the way because I can always buy a used factory *standard* computer with its wiring and that will fix the problem. I can however build my own kinda computer which would take commands from the ECU and convert them to 4spd control signals. Everything is fine except that I don't know in which order to switch gearbox solenoids.
    At the same time I don't want to seek for the solenoid on-off patterns by try and error method, for it could damage the transmission. I think I would find the info I need in service manuals, but I have no idea on where to get them.
    This page on lextreme forum may help
    http://www.lextreme.com/forums/showthread.php?t=9219
    Some time ago a link to this site was posted
    http://www.bahamutcars.com/workshop/
    A LOT of info there you can look through
    Jealousy is a curse
    vic
    The VVti 1 and 2 JZ , GTE,s run a 12 pin solonoid plug but are 4 sp autos , theres 7 solonoids in them . As to what they all do i dunno.
    Dave
    May 2010
    Moscow
    madmont, thanks, the on-off diagram found at your first link matches exactly what I was looking for, I will check if there's some more of useful info. According to the cambelt's message I was hopelessly wrong about the 5speed a/t
    cambelt, extremely valuable info. btw, do 89661-3A660 ECU s/n sound familiar to you?
