Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: BIO-E-FLEX anyone using it yet????
    Jan 2008
    queensland
    Default BIO-E-FLEX anyone using it yet????
    Are any Toyota engines compatable with this fuel(E85) ??. Should i run it in my 1uz-fe or is it only new cars?
    Default Re: BIO-E-FLEX anyone using it yet????
    AFAIK no Toyota is as yet.
    Im running it in my GT4, but only because its been tuned for it.
    3RZFE-T Backyard Mechanic
    Nov 2008
    queensland
    Be warned Guys on the BIO-E-FLEX fuel. Read the fine print
    "A new choice in fuel has arrived: Caltex Bio E-Flex, a fuel that contains up to 85% ethanol blended with petrol."
    So If you have been tuned to run real e85 out of the drum then this bio-flex is pointless and not reliable ethanol content unlike the stuff ya buy in the drums for $2 a liter
    Jan 2008
    queensland
    The fine print i have read so far says that its between 70-85% depending at what time of the year it is, i'm guessing colder months need more petrol than alcohol and the warmer months can get by with the full 85% ethanol. Is it much cheaper than pulp, cause i'm guessing that 'tuning' for E85 means richening up the A/F ratio considerably so is it really viable?
    Nov 2008
    queensland
    The stuff at the pump can varies from batch to batch. Were as the csr e85 from the drums is all ways 85%
    Bust remember is also requires 30% injector usage
    I cant see it being any different the 98 octane is its going to vary so much. 10% is alot when ya trying to get the a/f correct
    70% ethanol is still going to kill ULP98 for performance.
    Nov 2008
    queensland
    But how can you tune for it tho? when you dont know wat % it is from tank to tank? Its pointless for any performance car
    Sep 2009
    The timing has to be more advance with E85 (AFR about 9-10). I'm planning to run it in one my cars (non-toyota) but I expect to loose fuel economy as it requires 30% more then normal fuel and required to upgrade the fuel pump and injectors..
    ZZT231 sent me here
    Quote Originally Posted by Slowvac View Post
    (AFR about 9-10)
    What makes you think AFR's have to be around 9-10?...From everything ive read about ethonol, you aim for the exact same AFR's as you do petrol. Yes timing can be added as you are now running a much higher octane fuel but it is not a requirement of E85. 9 - 10 AFR sounds more like tuning pure methonol....
    JZA70|R / 12.45 @ 111 mph.
    No, you do need to run AFR's much lower than that of ULP.
    The confusion comes from what a value of 1 lambda is (which is what WB-EGO sensors use).
    1 lambda of ULP is 14.7:1 (as we all know).
    1 lambda of E85 is 9.7:1.
    Read: http://www.v-eight.com/tech_forum/vi....php?f=8&t=781
    This describes it:
    Quote Originally Posted by ed
    if your tuner is used to petroleum fuel and has his lambda sensor calibrated for this and doesnt want to change it, a stoich mixture is lambda 1.0, AFR 14.7:1. now stoich is stoich, so for E85 a stoich mixture will still read lambda 1.0, AFR 14.7:1 - you just have to do your own conversion on paper or in your head AFR 14.7 = 9.7. so if you then tune the car on E85 and power enrichment give yous rich reading of AFR 12.1, you know thats actually 7.9 - perfect!
    Ahh good reading cheers for that.
    toyota Tundra and Sequoia (5.7L V8) are Flex Fuel Vehicles
    Jan 2008
    queensland
    Big call; that remains to be seen.
    Jul 2007
    doesnt remain to be seen at all. you WILL make more power IF the engine is set up for it*
    *this means lots more compression, timing and/or boost.
    Jan 2008
    queensland
    Yeah I guess your right in that respect but how do you switch between tunes ie;running on E85 one day then Pulp the next,is there a switch on the dash in the new commodes, there isn't E85 bowsers everywhere and how will it stack up price wise?
  1. manual flywheel bolted over flex plate??
    Last Post: 06-07-2006, 08:11 AM
