Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
Thread: BIO-E-FLEX anyone using it yet????
    Jul 2007
    Default Re: BIO-E-FLEX anyone using it yet????
    neg rep for bible bashing/trolling in tech.
    douchebag
    Haha sauceman lay off the sauce.
    Read the rules. "No god talk*"
    (*unless happy to see both sides of the argument which GOD bashers dont-hence see above)
    So we sit around for jebus to fix our problems? Wheres he been for the last, oh i dunno, 2000 years? Behind the couch?
    Pretty sure God gave us brains to figure out our world's problems, as he invented that wonderful stuff called yeast which makes great stuff called Alcohol!
    Now as much as I'd like to believe that it was made so we could get well lairy, I'm sure that powering our cars is a worthy cause! especially when using our waste for benefit with no cost to the environment.
    Sure oil might not run out soon, but it is getting bloody expensive!
    Back to topic, are those ethanol sensors binary output or linear? If they are 2 state, what happens when you have mixes of E85 and 98?
    Ps. whose going to be the first to bag 300kw on a 1j with stock turbos?
    If in doubt power out
    Jul 2007
    Quote Originally Posted by Hendo View Post
    from what i've read the holden ecu only has 2 maps. E85, and straight petrol. so that would most likely be just a binary sensor too.
    no doubt that in the future you will see much more refined versions which can adapt to any amount of ethanol concentration. it's still only early days after all
    Depends in which application. The sensor for the ProEFI is linear, so it can give you an exact percentage of ethanol content in your tank regardless of what else is in there.
    On E85? who knows.
    Jak on the other hand with c16 and nos...
    369kw
    http://www.toymods.org.au/forums/sho...t=cressida+1jz
    Quote Originally Posted by RONA View Post
    Never happened, hasnt updated the thread since early 2008.
    JZA70|R / 12.45 @ 111 mph.
    Dec 2008
    south australia
    whatever it runs in the new comode it can can run on any mix ratio up to e85
    I mean how the hell would you be able to tell everyone that they have to have a near empty tank before refilling your car with a different fuel type . Not to mention the liability issues with a car that would slowly decompose when you run mixed fuel and its not designed to .
    I have it from the source it will run on any mix you put into the tank from straight unleaded/premium or E85 in any mix ratio of those three fuels!!!!!
    2 maps ECU pshhh we may not be a merc but we can see the stupidity behind trying to sell a car that you have to empty of one mix before refilling . I guess ford will do that tho
    oh and thanks for putting me straight with the GOD making sure we will always have enough fuel for our needs as the athiest in me had doubts . as this is the case I will sell the 18rg motor and go buy a 427 big block for the car .pffft god botherers
    Last edited by machschnell; 23-09-2010 at 05:14 PM. Reason: they didnt read my siggy
    I'm an atheist but it's not my fault it's the way GOD made me
  8. #38
    Dec 2008
    south australia
    plus rep
    Quote Originally Posted by Hiro View Post
  9. #39
    Custom ****** 1st year Apprentice
    Nov 2008
    I have a ProEFI 128 ecu for my supra, the proefi sensor is actually just a standard GM sensor that is made by Seimens
    I have both (Ford on left, GM on Right) and will test them on the same batch of fuel:
    It measures the fuel flowing through it and outputs a variable digital frequency signal depending on the amount of ethanol, the pulse width of the signal indicates the temperature of the fuel.
    You use that to adjust/slide all the maps (fuel, spark, boost etc etc) infinitely on the fly (ie 4th dimension) depending on the percent of ethanol in the fuel.
    EG one tuned for normal petrol and one tuned for E85/E98.
    The new flex fuel vehicles don't actually use a physical sensor any more.
    They use what is known as a 'virtual sensor'.
    It works when the fuel gauge goes up, then it stops all emission controls and reads off of the 02 sensors to calculate the percentage of ethanol.
    JZA80 Supra Aerotop undergoing 3UZFE VVTi + Twin Turbos / Getrag 6 Speed conversion
  10. #40
    Jul 2007
    Quote Originally Posted by machschnell View Post
    ehh. that's what the drive review said brotato......
  11. #41
    Aug 2008
    Down
    The old seven and half finger palm.I like it
  12. #42
    Dec 2008
    south australia
    dont know about you guys but my granda WAS AN APE
  1. manual flywheel bolted over flex plate??
    Last Post: 06-07-2006, 09:11 AM
