now it makes sense, many years ago a repupatble guy told me a 3sge can bolt into an ae71, now I can see how.
correct t and g bellhosuings are interchangeable. i think there is a slight difference with one having one extra aligner pin maybe.
so in theroy you could also bolt a t-50 (fromt t-18/ta22) to a 3s and it would theoryetically work. Brett (?) in tassie has been running a t-50 behind of a 1ggue in his corona for a fair few years i think. i was considering putting a 1g into a t-18 also (never happened). but yes these is some swapping available there.
also dont forget to check the spiggot bearings, im not sure if you need a different size for different boxes
dunno about the mounts being bolt in though sam, unless a sa63 or st141 cross member and mounts bolt upto the ke70 chassis...
also careful, check what box st141 actually uses, i have a bad feeling they all have the shitty boagwarner 4 or 5speed.
Yeah ae71 is correct, the some of the "S" engine powered Corona's did indeed have a Borgy box instead of the Toyota box. The SA63 Celica was fitted with a W5x box.
cheers Chuck.
MS51Crown Coupe,
Kiwiland is usually were they come from.....in the cars we got borg warners they usually got T40s..........ST141 Coronas and the like. They do sell for a bit over there because nearly every Lotus 7 replica over there has one of those bellhousings in it behind a 3SG
Yeah the "Button Plan" for local content in Aussie built cars sorta screwed us royally for those odd bits and pieces.
MS51Crown Coupe,
