Results 16 to 23 of 23
Thread: 3SGE BEAMS 6speed bellhousing
    May 2006
    tas
    Default Re: 3SGE BEAMS 6speed bellhousing
    Quote Originally Posted by "Z" UTE View Post
    Yes essentially the same gearbox, but the front section/bellhousing is then only suitable for the 1G series of engines, not the 3S's.
    Got a funny feeling that the "G" bellhousing bolts to a "T" engine, but the starter or clutch slave is on the wrong side. Way too many sleeps ago.
    cheers Chuck.
    correct t and g bellhosuings are interchangeable. i think there is a slight difference with one having one extra aligner pin maybe.
    so in theroy you could also bolt a t-50 (fromt t-18/ta22) to a 3s and it would theoryetically work. Brett (?) in tassie has been running a t-50 behind of a 1ggue in his corona for a fair few years i think. i was considering putting a 1g into a t-18 also (never happened). but yes these is some swapping available there.
    also dont forget to check the spiggot bearings, im not sure if you need a different size for different boxes
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    now it makes sense, many years ago a repupatble guy told me a 3sge can bolt into an ae71, now I can see how.
    May 2006
    tas
    dunno about the mounts being bolt in though sam, unless a sa63 or st141 cross member and mounts bolt upto the ke70 chassis...
    also careful, check what box st141 actually uses, i have a bad feeling they all have the shitty boagwarner 4 or 5speed.
    -JZX83 in the build
    <3 7M sludge pump
    Yeah ae71 is correct, the some of the "S" engine powered Corona's did indeed have a Borgy box instead of the Toyota box. The SA63 Celica was fitted with a W5x box.
    cheers Chuck.
    MS51Crown Coupe,
    oh sorry I meant just relative to the gearbox, in this case another model of T50 that bolts in to the mounts at least.
    Nov 2007
    There is actually a *S to t50 bell housing that exists. I'm not sure which cars they were standard in but I own one of these bell housings (long story) and I know of one between a beams motor and a sprinter t50 in a lotus 7 replica.
    Kiwiland is usually were they come from.....in the cars we got borg warners they usually got T40s..........ST141 Coronas and the like. They do sell for a bit over there because nearly every Lotus 7 replica over there has one of those bellhousings in it behind a 3SG
    Yeah the "Button Plan" for local content in Aussie built cars sorta screwed us royally for those odd bits and pieces.
    MS51Crown Coupe,
  1. KE55 3SGE Beams Conversion
    By filthman in forum Tech and Conversions
    Last Post: 08-03-2012, 07:59 AM
  2. Replies: 8
    Last Post: 28-02-2011, 09:00 PM
  3. TUTORIAL: How to build a 'cheap' 5S-GE motor from 5S-FE
    By bajachris88 in forum Tech and Conversions
    Last Post: 21-07-2010, 09:15 PM
  4. 3sge Beams & J160 q's
    By mattysshop in forum Tech and Conversions
    Last Post: 25-05-2010, 08:48 PM
  5. 3sge Beams in KE25 - Flywheel and Clutch
    Last Post: 15-08-2007, 10:43 PM
