Results 16 to 25 of 25
Thread: 1GGTE running like a pig on boost - help
    Default Re: 1GGTE running like a pig on boost - help
    Quote Originally Posted by JustCallMeOrlando View Post
    If you can't work out the body wiring, don't worry about it. Just wire an external globe to it, sure it's not as nice, but it will work, and going with the theme of the build, it's consistent
    Have a search for the thread about how to check the codes, it'll have the procedure and the codes.
    Stomps, PM mullet, he has a grenaded 1G with knock sensors.
    cheers.. will do..
    Stomps
    ok sorted the problem out
    when changing knock sensors (thanx robin) i noticed one of the ends on the fuel up VSV was snapped so i glued it back on, so not sure which it was that fixed the problem knock sensors or VSV.
    Either way car runs sweet as now thanx for all that replied.
    Adam
    Yello and black AE86 J-blood obesity kit - Built 4AGE
    Blue X70 Cresta 1GGte
    Aug 2009
    vsv?
    whats that
    Project:RA65 with an engineered 1ggte conversion.
    Daily:MA61 - 5me stock auto shitheap.
    vaccum switching valve
    RA23 - Twincharged
    JZZ20 - Daily
    located in a PITA place to get to with the motor in the car... under the inlet fannifold..
    Stomps
    Fuel up? I don't follow...The only VSV I know of under the inlet manifold is for the TVIS.
    maybe not fuel up then... but according to the pic i found there are 2.. then one on the firewall.. the one towards the front of the car said fuel up... maybe the diagram was wrong.. but whatever it was.. its now fixed..
    Stomps
    really one Gz have tvis?, it must be that then - thats what that diaphram valve is for then.
    Well you learn new things every day thank you for the insightfull insight hobbit.
    get it orlando bloom is that fag chops off that crappy movie... i crack myself up sorry
    anyways
    all that would make more sense.. no tvis hence not enough air hence turbos boostin hard making more noise blowing heap of fuel out the back sluggish performance cos its not getttin enough air yey another mystery solved dear watson
    Hey, I didn't pick the name. A drunken Stitt did.
    haha yeah i wasnt havin a crack just hung over and easily amused/distracted
    ooo shiny things...
  1. My high compression + boost concept
    Last Post: 18-06-2012, 09:40 PM
  2. Eboost and Boost Issues 1GGTE
    By Trent-KE30 in forum Tech and Conversions
    Last Post: 13-05-2009, 05:50 PM
  3. Boost Leak Tester
  4. 1GGTE 12 pound boost problem ? i need some help !
    Last Post: 29-12-2005, 08:12 PM
