Results 1 to 13 of 13
Thread: Excessive current draw?
    Default Excessive current draw?
    I've been having problems with the battery in the Century going flat after a week or so. It's a giant truck battery and only about a year old so it shouldn't be dead already.
    Anyway I just checked the current draw with everything supposedly switched off, and according to my multimeter it's a bit under 2 amps. Sounds a bit high to me - or is this normal?
    Default Re: Excessive current draw?
    Sounds too high.
    Pull all the fuses and put them in one by one to see if you can narrow down the circuit pulling the current would be my suggestion
    Wilbo's JZA80
    Wilbo's JZZ12
    Do you have any amps in it?
    Hello.
    no info in engine or wiring book as to static draw, but 2amps is stupid high.
    pull fuses one by one and note drop in current until you find the culprit.
    perhaps disconnect alt first, see if it is leaky diodes
    may be a silly question, but how do you actually measure current draw?
    is it by simply switching your MM to amps and putting it inline between your positive or negative battery pole and its respective terminal?
    JZA70|R / 12.45 @ 111 mph.
    Quote Originally Posted by JZA70 R View Post
    yep. just don't try to start it hooked up like that
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Quote Originally Posted by roadsailing View Post
    Or you can use a clamp meter without disconnecting anything, good for seeing how much current something draws when it going.
    Clamp Meter Example
    Hello.
    Not quite roadsailing.
    Apart from using something similar to what willwal has posted, to measure current you will need to break the circuit and put the multimeter in series (in-line) so it becomes part of the circuit - ala click. So the easiest way would be to remove the fuse and measure it from there, PROVIDED you know there isn't a known issue with the fuse blowing.
    To measure voltage, you are connecting up the multimeter in parallel so the original circuit remains unbroken - ala click
    Quote Originally Posted by big_zop View Post
    Yes quite big_zop, there are unfused connections to the positive terminal and it will work if you put the meter between the positive terminal and the positive clamp (or negative) i'd suggest using a cheap meter for it, and most of them go up to 10 amps (from memory), and if you have a 10 amp current draw your battery will be going flat stupidly fast.
    that way you will be checking every single wire, and not just the ones that are fused, for example a 6 ohm resistor might have somehow stabbed into the started motor cable and touched ground.
    anyway i got as far as peasuring what the current drain was on my car, but never found out what the cause was, I just unhooked the negative terminal every night and put it back on in the morning while i was putting half a litre of water into the radiator.
    www.vicdrift.com
    Ok, I did misread the way Todd put it as putting the two probes of the multimeter between the positive and negative terminals.
    But I suspect that is how Norbie got his 2A figure but now needs to determine where the draw is coming from, and with something as complex as the Century, its going to be quite a task.
    wa
    Around 2 amps is definately way to high, you would be expecting to have around 0.05amps
    Measure the current draw and pull the fuses to find the circuit at fault.
    Once you have found the circuit with the current draw put your multimeter across the fuse and start disconnnecting plugs in that circuit to narrow it down further.
    First thing to check for is any lights/globes being left on.
    Glovebox, boot, etc switches fail leaving the globes turned on which you dont notice as the compartments are closed.
  1. using a solid state relay on a twin outlet coil.
    Last Post: 11-02-2010, 09:03 PM
  2. Earthing kits - myths or truths? (modem size warning)
    By Mos in forum Tech and Conversions
    Last Post: 31-05-2006, 12:38 PM
  3. Starter Trigger wire Current Draw?
    Last Post: 07-11-2005, 07:23 AM
