Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
Thread: Out of fuel -> Now wont start
    dirty little Grease Monkey Cam-Rush's Avatar
    victoria
    Talking Re: Out of fuel -> Now wont start
    i once ran my 13BT almost out of fuel, and it died about 5 times on the way home, then wouldnt start again, i put 20 litres of optimax in it, and it still wouldnt start.
    i rang my mechanic and he said it sounded like blocked injectors.
    i got him to tow it and check it out, after about $70 for having the injectors cleaned it went fine again, he advised me that an EFI car should never be run to less than 1/4 of a tank.
    hope it gets going soon! i know what its like to have to walk down the road to try fix my car a few times a day.
    PS as someone else said before, did you put in ethanol fuel?-i put a tank worth in my KE35 once and it kept stalling, and generally ran like a dog.
    Signatures must be no more than 5 lines of text at 1024x768. Advertising is not allowed in signatures.
    Default Re: Out of fuel -> Now wont start
    i'd start with the wolf computer showing you 20,000 rpm.. that can't be good. Disconnecting the limiter wouldn't do anything anyway IMO... because doesn't it mean the ECU still thinks the engine is going at 20,000 RPM... hence cutting it off coz there is no map map at that range and the ECU has gone cuckoo.??
    Quote Originally Posted by Vios-GT_07
    Very true, the hand controller has been spouting crap for awhile though, I will tow it down to my tuner(luckly about 3 kms away). However I am still not sure on spark or compression, so that will be checked first.
    GT4 Freak, and Conversion King Squid's Avatar
    Don't you need to bleed the injectors of air after running out of fuel? I thought so, but I have never run completely dry to find out!
    40 odd psi should bleed them pretty good
    they should be fine.. if there's fuel pressure, the injectors are opening.. (as shown by the wet plugs hopefully) and there's spark.. either the spark is at the wrong time.. or there is soo much or not enough fuel/compression..
    I chatted to a mate before and he said it might be a collapsed cat, and I couldent believe that I didnt think of it before, I need to check it out, even though the cat is only like 3 months old, it could be dodge. Hopefuly I will get to check some shit out on the weekend. At least it is back home for now(had a mate tow me up the hill to my house).
    I aint getting no spark. Not sure if its the coils or the wolf
  8. #38
    Quote Originally Posted by WindeX
    I am getting spark... my testing method was a little shitty. I am going to get some new leads and plugs for her, they current ones are shitty and I dont trust them and I thought I might aswell replace the plugs at the same time... I noticed the terminals on my coil packs had some surface rust, I was thinking that I should just use a wire brush to clean them up, this is fine right?
    Cheers dudes
  9. #39
    Tasmania
    Very random but try running a nice thick cable from your engine to the chassis.
  10. #40
    It seems that it is the wolf 3d, it is reading rpms all over the place, I am sitting in my car now(ahhh wireless) and watching it crank, I am getting readings of over 20k rpm!. Any ideas on this one, could it be a bad earth, or some other issue with my coils.
  11. #41
    I have found the rpm issue... this is quite concerning, the cam sensor had poped out, it had been ejected from the back of the head... the bolt was still there but the sensor was freely sliding in and out, she is cranking now and getting much closer to holding, but as she hasnt been started for sometime she is being stubborn.
    EDIT: Its alive, cant idle for shit, and the timing is way out, but it runs. Heaps cool, now to adjust the timeing.
  1. fuel setup
    Last Post: 12-09-2006, 08:24 AM
  2. VL fuel pump making strange noises and fuel lines rattling
    By phrostbyte in forum Tech and Conversions
    Last Post: 11-02-2006, 11:04 PM
  3. weak fuel pump? (1jz-gte lost alot of power)
    Last Post: 23-01-2006, 08:14 PM
  4. Replies: 1
