what is the injection parameters set up like? doesn't have something odd like 1 injection per 2 cycles or anything?
fluctuate between 12 and 17 is probably missing, and leting a bunch of air through which reads as lean.
is possible the sensor is not happy as well. check wiring.. and check with narrowband to see if it really isn't getting past stoich.
it could be that one or two cylinders have issues, and the O2 readings you see are averaged, but not indicative of what is happening on good/bad cylinders?
