Results 1 to 14 of 14
Thread: 4age 20v idler pulley part number
    Default 4age 20v idler pulley part number
    Okay, dont blast me I have looked everywhere and have found conflicting info, so I need help.
    Anyone know the part number of a 20v idler pulley (alternator belt, not timing)?
    Or can anyone confirm/deny its the same as a 16v? Ive heard 20v BT and ST are different.
    51LII is screeching her head off cos the bearing is screwed and its so damn annoying!
    Cheers.
    Toyota Car Club (Qld)
    Default Re: 4age 20v idler pulley part number
    Hey
    13505-16021 IDLER PULLEY AE101
    taken off this website http://4age20v.blogsome.com/category/4age-part-number/
    i can check tomorrow at work if you like.
    Cheers Craig
    Hey Craig,
    Yeah that would be good if you could! So far that is one of 4 or so different part numbers I have found for it across various sites and no idea which is right
    Thanks heaps!
    Dana
    Sep 2009
    i know they are different to the 16V pulleys...
    but thats about as far as i know..
    Craig D has solved all your toyota part related problems though, im repping it up!
    Hey Dana
    Checked the part number it's 1357016010
    It's not cheap about $210
    Holy crap that is ridiculous! I expected maybe $100 from toyota
    I'll keep it in mind, thanks heaps for getting back to me, appreciate it!
    Dont suppose anyone knows of an aftermarket one available?
    Just pop the bearing out and take that to a shop to match up.
    Sep 2009
    Buy a gates pulley catalog, and a set of verniers, there should be something in the catalog you can use/ make fit.
    Craig - bearing doesnt look to be a replaceable type, looks like its all part of the pulley
    Casey yeah that was my next step anyway, just thought surely someone's already been down this path before??
    Sep 2009
    Is it possible to change the belt length and use a 16V pulley? They may be a bit more common beingan aus released engine. I know a lot of guys that replace the gze pulley with a timing belt tensioner pulley, however I really haven't seen many threads relating to the 20volt, that being said the 20volt pulley is a replacement pulley for the gze also, so perhaps a timing belt tensioner may suit what your trying to do.
    Sorry I can't be of much more help I'm limited mainly to the 16v variants.
    Hmm i'lll do some more research then. Thanks for your help tho its appreciated!
    Junior Member Too Much Toyota GUN METAL's Avatar
    I had one custom made for my AE101 for $120 and made it so the bearing could be replaced with a common bearing.only took them a day to whip it up. heres some pics / details of mine.>>>> http://www.toymods.org.au/forums/showthread.php?t=60430
    note its for a GZE and is most likely a smaller pulley as its to suit a 175 mm crank pulley
    MY BELOVED AW11...Updated members ride thread>>>>http://www.toymods.net//forums/showt...=4584#post4584
    AW11s always welcome in my driveway !
    Sep 2009
    Part # 13570-16010
    That's for a '99 blacktop (AE111 BZ-R)
    I paid US $113.74 plus postage from Lithia Toyota in the US last year
    [email protected]
  1. 4AGE 20V gasket part numbers
    By CEL_1JZ in forum Tech and Conversions
    Last Post: 28-04-2010, 12:34 PM
  2. 7MGE air con idler pulley (Cressida - Supra)
    By petergoudie in forum Tech and Conversions
    Last Post: 05-03-2010, 10:23 PM
  3. 4agze Coolant Temp Sensor Part Number
    By mlaser in forum Tech and Conversions
    Last Post: 15-01-2009, 10:44 AM
