Results 1 to 6 of 6
Thread: ST202 Part numbers
    Bottled up Domestic Engineer charliechalk's Avatar
    Default ST202 Part numbers
    Just looking for someone to confirm which gasket I will be needing and if there is any difference between these part numbers for red top beams 3sge:
    16346-17010
    16346-32010
    toyodiy has dates as the difference.
    all help appreciated.
    Default Re: ST202 Part numbers
    I thought only ST204's were delivered to Aus?
    ... and they didnt come with red top BEAMS 3S's, or have you put one in it?
    The large part number diff between those two means there is probably a decent difference in design.
    or one has superseded the the other. If you quote one to Toyota they'll tell you if it has been superseded or not. then just get the one they say accordingly.
    MWP, he's got a beams red top in his st162
    thanks huy, I called them up yesterday, they just said it's a bad part number, so just missing from their epc?
    Just checked toyodiy, they have two part numbers for blocks (same change over dates) but the thermostat and inlet are the same.
    also I found this http://www.toyotapart.com/LAND_CRUIS...T-EG004-96.pdf which carried the same part number. should be the same part right? if so I'll buy one of the updated and one of the 16346-32010 and compare. I would have thought if it was originally used in the 1FZ it would have shown up or at least directed to the newer part on a full epc.
    which place did you call up? a bit odd, it should come up on their system.
    If not ask for a ST205 thermostat gasket.
    generally i call up frankston toyota as they're normally helpful and are near where the car is. will give them another call and ask about the st205 then.
  1. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 10:54 AM
  2. Auto Fluid Change - A341E - Part Numbers?!
    Last Post: 31-05-2010, 01:06 PM
  3. 4AGE 20V gasket part numbers
    By CEL_1JZ in forum Tech and Conversions
    Last Post: 28-04-2010, 12:34 PM
  4. 4agze part numbers
    By KARNAGE in forum Tech and Conversions
    Last Post: 07-09-2007, 10:26 AM
  5. Here are the SC12 / SC14 bearing part numbers
    By nick.parker in forum Tech and Conversions
    Last Post: 13-11-2006, 09:52 PM
