Results 16 to 25 of 25
Thread: 2jz-ge Surf
    wa
    Default Re: 2jz-ge Surf
    Do you know you can pull out the cluster and adjust a screw inside to get the tacho spot on? I did it for mine and its pretty much perfect like 100rpm out at 7k
    Nov 2011
    if the surf tacho is a 2lt3 diesel tacho i think u cant get enough adjustment with the screw
    u can with a 4 cyl petrol tacho
    ive seen a 1j vvti into a surf 2lte and the tacho was ok at idle but jumped all over the shop as u reved it
    Junior Member Grease Monkey nilprospects's Avatar
    Sep 2008
    yeah guys, ive had the cluster apart and adjusted the screw, and as "dumbass" says, its ok at idle and aslo ok at a constant speed, but as you rev, the needle jumps around. I'd say its because the 2LTE sending a magnetic pulse, and the 2JZ sending an electric pulse. I'm on the lookout for a tacho with an 0-8000rpm range, possibly from a celica/supra
    Sep 2008
    none of the local wreckers have any complete front chassis cuts for my conversion, but i have bought another ps box to replace my worn one, for "crossover steering"
    of topic
    - my 2wd hilux has been soaking my attention with the r34 skyline disc brake rear conversion
    wa
    Get a petrol tacho they have enough adjustment but only read to about 7k but they still do alright, most of the time i change before 7k because you're not making any more power anyway.
    Nov 2011
    Spartan auto lokka in the front diff makes them go everywhere without the expense of a SAS swap nor having to do a sump change so the diff don't smack into it. You really only need the solid axle if you want to get into rock crawling. And yes V6 4runner instrument cluster is the one. I use those with the 1UZ swaps
    His. 2005 GRJ120 Prado VX
    Junior Member Grease Monkey danielk's Avatar
    Fantastic work mate. Bet it is a bit of fun now!
    Any legality issues in going to the live axle/spring front?
    Sep 2008
    found a few front diffs to slide under the front now, and now that the brakes on my 2wd ute are done............ and xmas is done and dusted........... and theres a few public holidays coming up soon......
    is there much demand/interest for a live axle conversion on these surfs? I guess the conversion would be the same on a '98 onwards hilux too right?
    Dec 2011
    I have seen a few done, mostly down NSW/VIC though. Seen both four runner and surf done, leaf front and coil rear, not ideal on road and quite poor flex off road. If you are handy with the old welder you could splice the three link set up out of a 80/100 landcruiser in there, just as easy to get engineered as what you plan. Just remember measurements are critical. There is a bloke down here who runs a shop called buds customs who does this to newer hilux's. The other thing to remember is the ifs has wider diffs than a live axle, so to rectify this you will need a hub spacer kit, i think locktup 4x4 do these, they are net based and reasonably priced. The spartan lockers are poo too, if you are going to lock it go arb, only way to have a locked 4x4 that doesn't break axles.......
    TA23 Celica Convertable *Needs Paint*
    HZJ80 Landcruiser - For driving over Hondas
    Sep 2008
    Heads up club members, i've put this on ebay, runs out tomorrow, $5000 no reserve. Private offers are welcome
  1. 2JZ Water Pump onto 1JZ
    Last Post: 28-10-2008, 11:33 PM
  2. 1jz to 2jz
    Last Post: 30-11-2006, 07:52 AM
  3. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
