Results 1 to 13 of 13
Thread: z20/A70 hub comparison & 1jz engine bracket question
    Aug 2009
    Default z20/A70 hub comparison & 1jz engine bracket question
    hey guys, just wondering if the Z20 and JZA70 hubs, upper and lower control arms are the same...
    im doing a 1jz conversion and i wanna get a big brake kit for a JZA70 and fit it on my car, what im wondering is if the A70 hubs and stub axle are the same as the Z20 so all i need is the crossmember and not the hubs and everything..
    also, my 1jz at work has LF-Z and RR-Z on the engine brackets..
    arent they sposed to be LR-Z and RR-Z?? i thought the R and F was for sump location?
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    Default Re: z20/A70 hub comparison & 1jz engine bracket question
    yes hubs etc are the same except gz20,ga70 which have smaller brakes etc
    Aug 2009
    yeh shit mine is a GZ, god dammit more money lol
    Dec 2008
    western australia
    shoulda bought my shell .
    i beleive it might be up for grabs again . look in cars forsale
    Aug 2009
    you know i wanted to... i just dont have the space at the time..
    also, can anyone shed some light on the engine mount brackets?
    May 2008
    To double check if you have big brakes Toyota Used the same size dust shield from small and big brakes to theck if you have the bigger brakes the disk will be right up to the edge of the dust shield and small brakes if I recall you will be able to see at least 1cm of dust shield!
    1992 - JZA70 STOCK - SOLD
    Junior Member Backyard Mechanic zombie's Avatar
    those brackets are from a Z30 soarer, hence the -Z (-A for A70 and -X X81 etc etc etc)
    AFAIK the F and R isn't sump position it's the bracket position on the block (though I may be mistaken on this)
    1990 JZA70 R - BLMQZ
    m a n u a l
    Dark green mica
    14.118 @ 101.01 mph (Perth Motorplex, 24/05/06)
    252.1 HP (Hyperdrive, 11/11/06) / 264.2 HP (XSpeed, 24/02/07)
    Aug 2009
    Oh ok some handy info there, thats what i wanted to clarify cos im getting ready to do my conversion but i dont wanna get the motor on the crane and be like ahh fucck it doesnt fit up
    Quote Originally Posted by pandaah View Post
    fairly sure you'll want/need the JZA70 brackets to make it an easy fit into the Z20, the Z30 brackets probably won't line up with the cross member correctly
    m a n u a l
    Dark green mica
    Aug 2009
    god dammit your right they are different... just checked on the parts break down... uhh
    May 2008
    100% that z30 brackets wont fit your will need to obtain them from a JZA70 pm shane on supraforums hey may have what you need http://www.supraforums.com.au/forum/...-JZA70-Racecar
    KE25 legendary Backyard Mechanic Robbo's Avatar
    Jun 2006
    absolutely fuckall from a Z30 susp and brake setup will fit a Z20.
    been there , tried that myself...didnt work.
    All A70 and Z20 hubs are the same, no matter if it was a GA, MA , or JZA, the hubs are F/R are exactly the same.
    front brakes , to fit the 302mm rotors all you need is the caliper mounting brakets and disc rotors for this conversion.
    calipers are the same, only the mounting brackets change.
    rears are all same same.
    all suspension components from any model A70 and Z20 are interchangeable
    hope this helps you.
    !!! BAN LOW PERFORMANCE DRIVERS NOT HIGH PERFORMANCE CARS !!!
    私のトヨタはある従って速い均一死んだ人叫ぶ!
    Aug 2009
    certainly does, have chased the crossmember and brackets from an A70.. thanks for all your help guys really helped me get the right bits for my conversion!
    Last Post: 12-07-2019, 05:11 PM
  2. 4agze ae92 AFM - Complete guide - doin it the hard way
    By ONETEN in forum Engine & Driveline Conversions
    Last Post: 19-03-2012, 04:30 PM
  3. MA70 --> JZA70 Conversion
