Results 1 to 2 of 2
Thread: E51 toyota gearbox info help pls
    Low rep 1st year Apprentice
    Feb 2010
    western australia
    Default E51 toyota gearbox info help pls
    can anyone tell me the specs for the E51 gearbox on a MK1 MR2 S/C GZE ?
    I have jacked it up and both wheels turn so i presume it's has LSD
    Main thing is getting a competition clutch and flywheel.
    1. Is it an 8 bolt fixing pattern for the flywheel to clutch ?
    2. Is the gearbox output shaft for the clutch the larger type like the E58 (21 spline,23mm approx dia ) ?
    Am using car just now so not easy to remove gearbox or driveshafts to check
    Help very much appriciated
    Junior Member Backyard Mechanic maurice c's Avatar
    Yes we Canberra
    Default Re: E51 toyota gearbox info help pls
    This web site will help with some of your questions.
    http://www.toyodiy.com/parts/q_J_198..._MR2_AW11.html
    Plenty of experience here on the forums otherwise.
    Getting your missus to help bleed the brakes isn't everybody's idea of quality time.
  1. Any info on the E51 gearbox 5th gear???
    By TERRA Operative in forum Tech and Conversions
    Last Post: 29-06-2009, 10:15 PM
  2. Toyota Crown MS63 Custom Wagon Info
    By TheToyman75 in forum Tech and Conversions
    Last Post: 28-09-2007, 12:31 PM
