Results 1 to 6 of 6
Thread: Effect of reducing compression ratio from 9.8 to 9.4???
    Chiba
    Default Effect of reducing compression ratio from 9.8 to 9.4???
    I've got a 5E-FHE here I'm rebuilding and due to time constraints it's looking like I can't wait for new 5E-FHE 9.8 compression ratio pistons to come from Toyota (no one else makes 5E-FHE pistons...) so I'm looking at the alternative of the much more common 5E-FE pistons which have a compression ratio of 9.4.
    What will the effects be of dropping the compression ratio this much, all other things being equal? Can I work out how much power I will loose somehow?
    Or can some one get me a set of 5E-FHE pistons in a few days???
    Default Re: Effect of reducing compression ratio from 9.8 to 9.4???
    If you just look at the difference in power between a 9.4:1 5EFE and a 9.8:1 5EFHE there's about a 10-15HP difference, assuming the rest of the engine is identical (you'd assume the ECU would be tuned to match the 9.8:1 ratio though so that might change things a bit differently though).
    Chiba
    Yea, I assumed that would be the case. Hmmm, I need a set of 5E-FHE pistons yesterday.....
    Jul 2007
    it wouldnt be a massive difference, could make up for it with a thinner headgasket?
    Chiba
    Looks like the ones I had on order are now in transit at the 11th hour, freak out over.
    We have already got a metal gasket to stick on, I should work out what the final compression ratio will be.
    All good now.
    Chiba
    double post...
  1. Can you calculate Compression ratio?
    By wagonist in forum Tech and Conversions
    Last Post: 07-04-2010, 09:23 AM
  2. Replies: 24
    Last Post: 13-01-2010, 09:53 PM
  3. 3t-gte factory compression ratio
    By celica gt-t in forum Tech and Conversions
    Last Post: 11-11-2007, 04:09 PM
  4. 3SGTE Engine rebuild; What compression ratio to go with.
    By Howieau in forum Tech and Conversions
    Last Post: 13-05-2007, 10:48 AM
  5. Selecting a compression ratio for a 20V
    Last Post: 05-07-2006, 10:09 PM
