Results 16 to 18 of 18
Thread: 5k rebuild.
    Aug 2010
    Default Re: 5k rebuild.
    spoke to Tighe Cams today. the solid lifter cams have quieting ramps and using hydraulic lifters on this cam would cause lifter pump. Hydraulic cams don't have a this ramp and using solids on these causes valve float. Both result in excessive noise and inconsistent valve movement.
    But the end result is Tighe will grind my 5k cam to 25-65 270degree 0.400" lift to suit solids lifters. They call it the Tighe 104.
    Aug 2010
    put the pistons in today. the big ends had about 1mm of play around the crank. Not happy Yhan!!!
    The crank has ovbviously been grond and measures a measely 41.42mm.... so i'm transplanting the crank out of the 4k which measures 42.42mm
    or use 40thou OS bearings?
  1. To rebuild, or not to rebuild?
    By Shifty in forum Tech and Conversions
    Last Post: 04-04-2006, 11:37 AM
