Results 1 to 8 of 8
Thread: removing f series axles
    Default removing f series axles
    hey guys,
    did a search couldnt find anything. Anyone suggest a way of removing the axles out of a IRS f series diff? (the short stubby ones coming out of the diff itself) The mark 2 trsm suggests using a special service tool that just looks like a slide hammer. However on the inside of the axles it looks like there is a little gear/mesh thing that keeps the axles form coming out.
    Might be a noob question but ive never worked on a diff before
    thanks!
    nath
    Default Re: removing f series axles
    I've used two cold chisels in the past
    There is a little 'C' type ring that stops the axles coming out - It will make sense when you get the first one out
    Wilbo's JZA80
    Wilbo's JZZ12
    I concour with Wilbo here, the shaft is retained into the diff casing by a simple "C" ring, When being installed the "C" ring is compressed into the relieved section of the axle, The same thing happens on removal the "C" ring is compressed and the axle slides out. I use 2 builders crow bars, and out they pop.
    cheers Chuck.
    MS51Crown Coupe,
    thanks heaps guys
    "edited because i am a peanut"
    Javal, I did not know that the drive shaft for an IRS had the same bolt pattern as a drum.
    MS51Crown Coupe,
    Just pull them, they'll fall out.
    Quote Originally Posted by "Z" UTE View Post
    My mistake, i should really learn to read
    By The Witzl in forum FAQ
  2. EOI - Cruise to Drift Aus Series @ Easter Creek
    By driftedmz20 in forum Previous NSW Events
    Last Post: 23-06-2008, 12:32 PM
  3. Guide: How to build a K series motor
    By oldcorollas in forum FAQ
    Last Post: 26-09-2005, 07:51 PM
