As for lack of spark / injection when cranking via the IGN key, I'd check to make sure that the IGN source that you are sending to the engine ECU has power when the key is in the cranking position and the IGN position!
How long has the engine been sitting? Is it possiable that the injectors have become stuck from lack of use for a long period of time?
You should be able to hear the injectors click if you earth / un-earth #10, #20 at the ECU... repeatedly manually turning the injectors on/off like this can help to unstick them if they are stuck...
