Results 1 to 5 of 5
Thread: 1jz not starting due to injector pluse
    Automotive wizard 1st year Apprentice
    Jul 2007
    Default 1jz not starting due to injector pluse
    My battery died on my 1jz cressida after not driving it for a month! Was running fine perviously. Tried charging it but battery was gone! Purchased a new battery a month later! Then tried to start it and it won't start. No injector pulse so no fuel feed into the motor any suggestions! thanks
    Default Re: 1jz not starting due to injector pluse
    If this conversion was done correctly, there should be an EFI main relay in the wireing, the output from this should have a fuse, check that fuse.
    cheers Chuck.
    MS51Crown Coupe,
    Jul 2007
    Yes the wiring conversion was done by sideshow! ok will try that out!
    No injector pulse is also a result of no ignition pulse.
    Check the ignitor
    Junior Member Grease Monkey ra28_miles's Avatar
    Mar 2009
    W.A.
    crank and cam position sensors?
