Results 1 to 14 of 14
Thread: 1uz oil starvation engine - worth keeping as spares?
    Default 1uz oil starvation engine - worth keeping as spares?
    So I screwed my last engine by starving it of oil.
    Whilst the problem is fixed NOW, I am left with an engine that died atleast from ONE obvious failure, but who knows what else.
    The main bearings died, so the crank would be scored and would the block to some degree.
    Who knows what's happened to the cam shaft and consequential buckets/valves, including the pistons and cylinders...
    I would only keep the engine for parts if there is anything useful on it that I might use in a later engine. EG - keeping rods just for the sake of having a set of rods isnt' really that interesting to me, as if I were to build an engine, I wouldn't use standard rods.
    Is there any particular reason anyone can think of for keeping the engine? My theory is that it's potentially damaged in various degrees all over which renders it scrap.
    Confirm or Deny?
    Facebook | LinkedIn
    Aug 2009
    Default Re: 1uz oil starvation engine - worth keeping as spares?
    usually its the crank that dies first mate, depending on where abouts in the engine the motor starved of oil..
    im rebuilding a puegeot 206 GTI at work that i got with a seized motor, although im keeping it for myself, the main bearings melted and they were thrown around the block in liquid form until it locked the crank solid..
    smashed them out, scrubbing the rods and crank with hydrocloric acid and a toothbrush to rid them off melted alloy, getting the rods resized and the crank grinded.. honing the bores and new rings.. just a light line bore on the mains and thats it, itll be running by the end of the week..
    top end is fine!
    like i said but, im keeping the motor for myself, if it was a customer id be forced to grind cams replace buckets etc... do the hole job
    id suggest stripping it and selling it in pieces, like get the heads done, sell them as reconditioned heads etc.. theres still money to be made in that engine
    Hrm - Good input, thanks mate.. Valuable.
    Facebook | LinkedIn
    These things are tough so you'd be surprised what would and wouldn't need replacing.
    I have a 'dead' engine just to dummy up new mods....makes life easier.
    Good for spares, even weird odd stuff you would never expect to replace.
    They aren't making any more of these things and even rebuilders are getting harder to come by cheap.
    there's 4 reasons i can think of
    Hoppers Crossing
    hey mate. my dead 4AGE was OK with the crank ground under - no issues at all. definately hang on to it! the rest of my thing was fine
    Alright, cool thanks guys.
    Holding it it is. :-)
    Facebook | LinkedIn
    Junior Member Domestic Engineer Hurricane's Avatar
    if it was me id keep it. unless u have no room for it.
    other wise ill have it
    every thing is fixable.
    dan
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    Top Gear style coffee table?
    MS51Crown Coupe,
    Hahah. I was thinking abotu the coffee table..
    Facebook | LinkedIn
    Eltham vic
    hi strad
    keep it
    even if its only used for dummy fitting projects
    ian
    Mar 2009
    Auckland
    easiest option since it is out is just check the crank by removing the sump. i wouldnt sell tho spare parts always come in handy
    object for the zen garden?
    HaHah zen garden...
    Facebook | LinkedIn
    Well the 1uz is very well balanced haha.
    If in doubt power out
  1. 1UZ non-interference engine? - How to check stuck valve?
    Last Post: 25-01-2010, 06:55 AM
  2. MA70 --> JZA70 Conversion
