Results 1 to 9 of 9
Thread: What is this part and what does it do? ( Borg Warner 35 BW35 )
    Junior Member 1st year Apprentice 4age_fun's Avatar
    Jun 2009
    Default What is this part and what does it do? ( Borg Warner 35 BW35 )
    If anyone knows what this is and the correct adjustment for it could they please let me know. Its a borg warner auto trans from a 1974 Toyota Crown. I am hoping its something to do with the bands as they are due for an adjustment.
    http://www.youtube.com/watch?v=rID9mNAHsOQ
    Tallahassee, FL USofA
    Default Re: What is this part and what does it do? ( Borg Warner 35 BW35 )
    Borg Warner 35
    Automatic Transmission settings – Bands.
    (1 lb/ft = 1.35582Nm 1Nm = .737562 lb/ft)
    Front band: Tighten adjusting screw to 1.1 Nm and secure with locknut. This is with a 1/4 inch (6.35 mm) spacer between servo piston and the adjusting screw.
    Rear Band: Tighten adjusting screw to 13.5 Nm, back off ¾ of a turn, secure with locknut.
    Capacity: 6.6 litres
    Fluid: TQ DEX 11
    Fitted in Toyota Corona (RT118) 1979
    Auto Transmission: Borg Warner 35
    Part No: T 710-35-004
    Model No: 0540-073
    Serial No: A 6796
    Some specs from aussiefrogs, \Thanks.
    http://www.aussiefrogs.com/forum/showthread.php?t=62208
    Jun 2009
    Thanks for the information but do you know if the part in the video is the rear band or front band. Thanks
    That was the front band adjustment the rear is adjusted externally
    Jealousy is a curse
    Jun 2009
    Thanks for that. Does the band in the video appear to loose?
    Hard to lell without using the spacer
    Jealousy is a curse
    Jun 2009
    Oh ok just one last question. Where is the location of the external adjustment screw for the rear band?
    Thanks again for your help madmont.
    it is on the drivers side of the case on top of the rear servo
    Jealousy is a curse
    Quote Originally Posted by 4age_fun View Post
    Look for a large stud that has a small square or hex head on it, with a jam nut against the case, maybe also has a washer.
    DON'T over torque it!!!!!!
