Results 1 to 7 of 7
Thread: toyota shims to suit LSD
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    Default toyota shims to suit LSD
    as in title, any idea if Toyota still stock shims to suit our diffs? i know Nissan still do
    using: http://www.toyodiy.com/parts/p_J_198...VZ_4101.4.html
    i have a gz20, so its a G series IRS LSD. looks to be factory lsd
    41361A SHIM (FOR REAR DIFFERENTIAL SIDE GEAR THRUST)
    with a few different thicknesses , looking to tighten it up without being a full blown locker
    has anyone here had much experience shimming toyota diffs? what is a good thickness to go with? etc
    87' z20 Soarer - 1jz Gt35r -
    Default Re: toyota shims to suit LSD
    someone was selling a higher rate spring for these on here in Engine/driveline etc. I think it was only $40 from memory and will increase the 'locking force'
    Junior Member Grease Monkey twiztd's Avatar
    Aug 2006
    toyota should still have them in stock
    i bought 3 of the thickest they had in local stock (WA) when I did my diff as I was in a rush - think i ended up with 2 x 0.25 and 1 x 0.30
    seemed to work nicely, but the car has always been having problems so it's barely seen the road
    Now - 1988 GX81 Mark II- 7MGTE, GT35R, TiAL 44m, Microtech, 550cc injectors, R154, Xtreme clutch, LSD.... Low boost tune done = 330rwhp@1 BAR...
    Then - 1989 MX83 - The big scrap heap in the sky...
    Aug 2009
    i gotta do mine soon.
    Project:RA65 with an engineered 1ggte conversion.
    Daily:MA61 - 5me stock auto shitheap.
    Quote Originally Posted by forey View Post
    They should be good to adjust the backlash back to specs due to wear on the clutch pack. If the clutches are worn out you will need new ones. I know the Hilux plates will fit the Supra LSD so should fit GX20 . From memory they were about $15 each from Toyota
    Jealousy is a curse
    vic
    The toyota shims tighten up the spider gears and not the LSD, ( well by a bee,s dick as it does move the side gear inwards) if you put the thickest toyota shims in the lsd will work shit hot because the spider gears are binding up on each other = not good .
    The bigger spring is the trick.
    Dave
    Tasmania
    Seamonsta pulled his cressida diff apart and rearranged the plates to get the lsd effect happening again as his was single wheeling all the time. I went for a spin and it definitely works well now!!! PM him for details. He tried the spring but in his opinion it did SFA.
  1. Replies: 0
    Last Post: 20-07-2006, 01:18 PM
