Results 16 to 20 of 20
Thread: Suggestions for oil pump replacement 4AGZE/GE
    Tallahassee, FL USofA
    Default Re: Suggestions for oil pump replacement 4AGZE/GE
    Are the stock pump gears made of powdered metal? These guys claim steel & closer tolerance's, no size increase, so if you gotta shim and increase the chance of breakage, this'll help.
    ...ttp://www.horsepowerfreaks.com/partdetails/Toga/Engine/Oil_Pumps/High_Volume/5127...
    http://www.horsepowerfreaks.com/part...gh_Volume/5127
    Chiba
    I thought Toga stopped making oil pumps for the 4AGE?
    Feb 2007
    Timaru
    Quote Originally Posted by oldcorollas View Post
    i think the 4A pumps open around 40-50psi when hot?? can't remember..
    Hot or cold, the oil pressure relief valve is always set at the same psi.
    Just when oil is hot, that it gets thin enough that most engines wont make enough psi to open it.
    The relief valve is there to stop over pressure when cold.
    Like the early mitsi's that split the oil filter off with too much pressure when revved cold.
    Quote Originally Posted by TERRA Operative View Post
    A guy from NZ tried to organise a buy for them about a year ago?
    and found no stock and they had stopped making them,
    so you may find that thye are on the list but not available.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    Quote Originally Posted by DX20VT View Post
    FWIW the old rally trick was to get a large screw-clamp and tighten it up around the base of the oil filter to stop that.
    www.billzilla.org
    Toymods founding member #3
    Apr 2010
    Thanks for the information.
    Ok, looks like there isn't really much to do. I will pull it apart and inspect it, and either get a new one or reuse the old.
    You think they would have caught that in testing.
  1. HELP - how to wire up a fuel pump
    Last Post: 21-06-2007, 12:15 PM
  2. 4S-FE Water pump equivalent
    By deeps in forum Tech and Conversions
    Last Post: 04-12-2006, 05:34 PM
  3. 3TGTE Oil Pump replacement - keeps blowing oil filters
    By ta23 in forum Tech and Conversions
    Last Post: 10-08-2006, 11:41 AM
  4. trying to diagnose a fuel pump or FPR problem
    Last Post: 07-08-2006, 09:21 PM
  5. Replies: 1
