Results 1 to 4 of 4
Thread: I need help changing ball joints on my ms65
    Nov 2008
    Default I need help changing ball joints on my ms65
    I need help changing ball joints on my ms65 , I have had a look , but i am worried about the springs .Can any one give me some tips please .
    Aug 2009
    Default Re: I need help changing ball joints on my ms65
    what are you worried about champ?.. once the car is jacked up and on axle stands, remove the lower shock absorber bolt, then loosen off the nut that holds the ball joint to the hub..
    seperate the LCA from the hub by giving the side off the hub a smack with a hammer to shock the ball joint loose, then either remove the ball joint (if its the type that can be unbolted) or remove the LCA from the vehicle and go down to your local pedders or suspension place or mechanic and theyll press in a new ball joint for you for cheap cheap
    if you are worried about the springs you might be better off taking the whole car to a mechanic.
    what about the springs is worrying you? how do you know the ball joints need to be replaced?
    are you wanting to change the balljoint at the end of the lower control arm or something else?
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Nov 2008
    All done now , Thanks for you help . wasent as hard as i thort.
  1. AW11 ball joints
    By mullett in forum Tech and Conversions
    Last Post: 07-06-2006, 11:26 PM
